Facts About The Supercharger
Old 03-08-2006, 02:05 AM
  #101
HighlanderMac's Avatar
Dang I wish I still lived in PA or NJ.. lol.. I woulda loved to get in on this one.
HighlanderMac is offline
Old 03-08-2006, 02:27 AM
  #102
Scion-ce's Avatar
you just concentrate on getting your car dynoed so we can put an end to this aftermarket header vs. stock header controversy
Scion-ce is offline
Old 03-08-2006, 02:29 AM
  #103
Hahahahahahaha... So sorry.. lol...
Unfortunately I work alot, and dont have anytime this weekend, maybe sometime next week during Spring Break.
Old 03-08-2006, 02:31 AM
  #104
kytc's Avatar
Hey highlander, are you running a cat on your exhaust setup?
kytc is offline
Old 03-08-2006, 02:34 AM
  #105
Not at all.. all I have is a resonator. I did when I had the stock header of course, but we will see what power gains/losses happen with an aftermarket header.
Old 03-08-2006, 02:40 AM
  #106
kytc's Avatar
Have you noticed any drivability issues, low end power loss without it? I'm getting ready to get my midpipe put on and I'm making sure that not having one won't make much of a difference
kytc is offline
Old 03-08-2006, 02:46 AM
  #107
Honestly I havent, aside from not having traction.. lol, but I DO know that I need a stronger clutch here soon. We will see how she dynos.. hope to be over 230 now, and over 200ftlbs.. but who knows
Old 03-08-2006, 02:51 AM
  #108
kytc's Avatar
Sounds good man, thanks
kytc is offline
Old 03-08-2006, 04:15 AM
  #109
terra_tC's Avatar
alright ill do a quote since i have a very nice book in front of me handy...
from the author 'maximum boost', Corky Bell's 'Supercharged':
"exhaust gas back pressure is a significant restriction to airflow through an engine/supercharger system. It therefore becomes nearly as important to get the hot exhaust out as to get the fresh charge in, It also happens to be a whole lot easier. Some lingering notions still exist that an engine must have back pressure from the exhaust or the valves will burn. This has never been true. Show me a race car with exhaust gas back pressure and I'll show you a looser.
Exhaust restrictions offer a novel twist in supercharged systems: the greater the restriction the greater the boost- at least as read on a guage in the intake manifold. IMAGINE the restriction with all the intake valves closed and with the supercharger still pumping. We'd have a whopping amount of boost BUT, alas no power. Decreasing the restriction may produce the perception of lost power (from reduced boost), but keep in mind that the supercharger will pump what it's sized for. The more easily the air gets through the system, the more airflow will result, and therefore more power, even if the boost is less.
...a proper header is as valuable to the supercharged engine as it is to its atmospheric cousin, or more so, since it is asked to flow more air...one can almost always benifit by replacing the header with a higher flow unit."
just beating what you guys already said into the ground, and trying to put some information on the table.
terra_tC is offline
Old 03-08-2006, 09:05 AM
  #110
ForceFedRacing's Avatar
Originally Posted by desertheat
I agree to a point after thinking the whole thing over and trying to decide the level of insanity this post has brought. There is a give and a take to backpressure on a sc like the vortech. Just to make things clear, the vortech sc DOES NOT NEED BACKPRESSURE TO OPERATE *lol*! Since you have little boost until rpm's rise, usually in the 1.5-2 psi range then the engine is acting like a n/a engine. With very little to no backpressure bottom end will suck donkey nuggets. With more backpressure you will get better bottom end. But the catch is you will LOOSE top end up once airflow increased at X psi. You must find the perfect balance. Once you hit 4-5+ psi the flow in the exhaust increases to the point that a header / high flow cat is needed to reap the benifits of the boost you are producing. Since this type of sc likes to play in the upper RPM anyways and you only run into the uppermost rpm when racing, that is were you want to focus your power. A header with 2.5" exhaust will be perfect. You do NOT want to equal the backpressure of the stock system period if you want good dyno numbers or drag strip results as your time at either will be spent in the upper RPM only. Do I reccomend some backpressure in the system? Yes. Leaving one stock cat in the system is plenty of backpressure to give you decent drivability in the lower rpm and enough flow in the upper to win races. End of story.
Hey man do you own a dyno or a shop? How many Supercharger kits have you installed over the years? Over 200? Have you gone through ATI or Vortechs orientation? I dont mean to be rude but we here at FFR have all the above. What you explain is how a Turbo kit works. To help you out though I will post some dyno results both with and without the stock cat and header and then a Megan Racing header and an Alpha header. Then to finish it off I will do one with a header and a special flowing cat. I think this is necessary to prove beyond any doubt that what were saying is fact. We only say what we know to be true because its the good results that come from our advice and products that will make our customers the fastest and highest power Supercharger systems out there. We will be spending some time this weekend testing and tuning different setups. The ones I just mentioned and then our brand new 11psi kit! This will be an awesome weekend I think! We are looking forward to seeing what this new pulley and tune will be able to put down and hopefully clear up once and for all some important issues in the SC TC World. When we get everything uploaded to the computer we will try and post everything we can.
ForceFedRacing is offline
Old 03-08-2006, 09:25 AM
  #111
Nick06tC's Avatar
Hey man do you own a dyno or a shop? How many Supercharger kits have you installed over the years? Over 200? Have you gone through ATI or Vortechs orientation? I dont mean to be rude but we here at FFR have all the above. What you explain is how a Turbo kit works. To help you out though I will post some dyno results both with and without the stock cat and header and then a Megan Racing header and an Alpha header. I think this is necessary to prove beyond any doubt that what were saying is fact. We only say what we know to be true because its the good results that come from our advice and products that will make our customers the fastest and highest power Supercharger systems out there. We will be spending some time this weekend testing and tuning different setups. The ones I just mentioned and then our brand new 11psi kit! This will be an awesome weekend I think! We are looking forward to seeing what this new pulley and tune will be able to put down and hopefully clear up once and for all some important issues in the SC TC World. When we get everything uploaded to the computer we will try and post everything we can.
Id like to see some non biased testing.
Nick06tC is offline
Old 03-08-2006, 10:01 AM
  #112
Originally Posted by terra_tC
Exhaust restrictions offer a novel twist in supercharged systems: the greater the restriction the greater the boost- at least as read on a guage in the intake manifold. Imagine the restriction with all the intake valves closed and with the supercharger still pumping. We'd have a whopping amount of boost BUT, alas no power. Decreasing the restriction may produce the perception of lost power (from reduced boost), but keep in mind that the supercharger will pump what it's sized for. The more easily the air gets through the system, the more airflow will result, and therefore more power, even if the boost is less.
I cannot believe anyone actually wrote something so stupid! There is never a time in a four cylinder motor when at least 1 cylinders intake valve is not open!!!! He talks as if there is a time like that! Is that a real book? If it is that point he just tried to make is the dumbest thing a pro has ever said. Consider that a 2.4 Liter motor thats rotating @ only 4000rpm opens its intake valves over 30 times a second per cylinder. That means the supercharger has to pump 2.4 liters of air at least 30 times a second just to create 0psi. Problem lies in the fact that a supercharger uses the engines resistance to pump air obviously. The resistance is the reason a supercharger "whines". When you take away resistance you take away a superchargers "fuel". Thats why its said that a supercharger takes energy from the motor to produce it. Resistance is key and I am looking forward to showing everyone first hand that this is true when we do our tests this weekend. Hopefully this will end the debate and we can move on to doing other things that will yield some great results!
Old 03-08-2006, 10:09 AM
  #113
non biased? Why would we be biased? We dont make superchargers! Were also not children here trying to stomp our feet and prove a point. Were professionals trying to help people appreciate something that we see regularly that could benefit them. If you want call Vortech as some of the guys did that have called our shop this week. Some people unbelievably enough didnt even believe them! That made me think Im not out to change everyones minds with the testing this weekend , just trying to put some numbers down that will help those who are mature and open minded.
Old 03-08-2006, 10:56 AM
  #114
Yablargo's Avatar
its pretty well known that you boost less with a more open exhaust with that type of FI setup. However, that doesnt necessarilly mean you will make less power.
This topic got rehashed ad infinitum over on the nt.com boards. Its not as simple as you make it sound.
Yablargo is offline
Old 03-08-2006, 12:20 PM
  #115
zer0's Avatar
Well said.
zer0 is offline
Old 03-08-2006, 01:01 PM
  #116
Music City Scions
rhythmnsmoke's Avatar
lets put it this way...the way I sit right now with my supercharger, I will walk on stage 0's all day long...I dont care who is driving the car, I will beat them time after time. On another note, the way my car sits right now, I cant beat stock Evo's or Sti's but the turbonetics kit will. I think by the end of this week I will be able to hang with them, and when I get my clutch and flywheel in next week, I really will be able to hang with them if not beat them by a car or so.
I will eat your S/C with a NA tC
....heehee..
Seriously though, I will be boosted before the April show here. I will be up for a simple game of poker. I'll see your "S/C walking over a Stage 0 any day"....And I'll raise you "my g/f will eat you in the 1/4 mile". I won't even drive, I'll let her do the driving. That way, it will be fair.
Ive come to the realization that you live in a Scion fantasy world, although I will bet on your side that your girl drives better than you...I would rather a more fair race
When your boosted in April, come up to Englishtown Jersey, Ill even paypal you the money for gas on the way up cause I already proved that I can beat a stage 0, you have yet to prove that you can beat a supercharger. Im gettin real tired of this bullsh!t, you arent even boosted yet so how can you even speak for christs sake...I dont care about your "rollercoaster rides" in ZPI vehicles cause thats not your car. Like I said, the offer still stands, I pay for your gas on the way up here, you bring all your buddies so they can witness this and we put an end to all this.
Be ready to paypal me then... I will meet you half way, to save on some gas. Now don't go backin out when I get there, cause I'm not waisting all that time just for you to go coward on me. And as far as I'm concern you have yet to prove you can be a Stage 0....oh wait, I almost forgot, you raced an Un-tuned, Non-supporting mod, Stage 0, so I guess that counts..
rhythmnsmoke is offline
Old 03-08-2006, 01:18 PM
  #117
Munch's Avatar
I didn't even want to get into this debate, but I can't let this one slide sorry. Wow that is so . I must be missing something here. Sorry to ____ on your Cheerios, but the last time I checked. The Stage 0 doesn't come with anything to tune it. You are supposed to bolt this thing to the car and hope that the car doesen't blow the hell up . It doesn't even come with injectors . So for your info, he raced a Stage 0 ZPI powered TC and beat the kid. Now the only way to tune that kit is to get an Emange or better system and a set of injectors. But then that wouldn't be a stage 0 kit anymore now would it . I would love to see you make a fool out of yourself trying to race a supercharged TC with your car. It would be entertaining to say the least ].
Munch is offline
Old 03-08-2006, 01:29 PM
  #118
Stu_Gotti's Avatar
Stu_Gotti is offline
Old 03-08-2006, 01:40 PM
  #119
Team No Limitz
Simplyscion's Avatar
As I said playa, I have nothing to prove to you, but at this point, you got a whole lot to prove to me...Im not meeting you half way to go run someone I know I can beat with ease...Englishtown NJ...One of the finest tracks on the East Coast, come see me, we are in the same class...get the paypal account ready homey.
Simplyscion is offline
Old 03-08-2006, 02:06 PM
  #120
Scion-ce's Avatar
Just race for slips already (F&F style) That way whoever was talking the most BS walks home and the one who actually backed it up, now owns a s/c tC and a tC-t
Scion-ce is offline
Quick Reply: Facts About The Supercharger
