Few questions about turbo kit
im about to finsih up on my turbo kit it took my awhile and i posted up a while back before
i am about to order a custom 2.5 mid-pipe but i want to keep my HKS axle back that i have on my car now but i realized that the piping diamter is i believe 2.25 im not to sure so what exhausts can i use for or is there a way where these two parts can fit together
finally i ahve to mechanical guages oil pressure and boost- obvioulsy its mechanical so i got a vacum manifold but as far as hooking up everything i dont know where im going or what kind of hoses i should get for the guages because the kid only sold me the guages- i alsot dont know what else to tie to the vacumm manifold open to any help possible thank s
they will bolt up and there is a rubber hose on your fire wall leading from your TB to your intake manifold. remove this and replace it with another that you can cut in half or cut the existing vacuum line in half and tap your vacuum manifold there. to the VAC block hook up your BoV, WG, and boost gauge. if it's an auto meter boost gauge you are going to have to use the rubber adapter that comes with the gauge. you can buy a boost gauge install kit off their website. as far as the mechanical oil pressure gauge you can tap that off the head using multiple T's from where you tap your oil feed line.
cessblood
09-15-2015 06:50 AM
my06tc
06-25-2015 12:18 AM
