Finally got on a Dyno....
Originally Posted by Enrique9876
^^^ its actually a precision turbo housing (thats how i got it flanged mitsu instead of t3) but it has real garrett internals of course.
i decided on the gt30r because my plans for the build exceeded 300whp. the way i have it understood is that the gt28r falls out of its efficiency range just past 300whp (even though the garrett site claims otherwise).... so the obvious choice was the gt30r.
also the optimal motor displacement for a gt30r turbo is 1.8l to 3.0l ............... and what is smack dab in the middle of that range?
2.4L
thats how i decided
2.4L
thats how i decided
If the GT28RS/30R is choosen, it would probably give you much better efficiency at 10-12psi with lesser back pressure created at hot side.
Of course I also read that the spool time would again be alittle slower if compared to a 16g (since inducer/exducer are smaller). But I suppose the gap difference or spool time can be reduced if you use a EL manifold as the exhaust pulses from the runners would be more consistent (pulses line up one after another) and converge at the collector, thus driving the turbine wheels faster + the fact that the CHRA is ball-bearing......
Yes, I think you are right Enrique.... The GT series would be a overall better choice even if you do not boost above 12psi + it gives you room to grow in the power department after beefing up the internals.
Good work and info to save me dough in the long run
I actually came across research articles stating that EL manifolds will spool a turbo slower than a log style mani.
i am at full boost by 3k ish as opposed to 2500 but so what... the pull of the car makes for an AWESOME street car.
500 rpm can be the difference between winning and loosing. Tunning plays a part in your dyno numbers just as much if not MORE than the mods you have to go along with the kit. Different dyno's on different days will yeild you sometimes less and sometimes more, hence the reason why I don't pride on reaching a certain "magical whp" number.
also ive driven both turbos at 14psi and the 16g I FELT "fell" off later in the RPM band and the gt30 keeps me pinned to 6200.
again im only going by feel obviously i never raced my car with the 16g and the 30r at the track so i cant give you accurate numbers about my car at 14psi
Yeah I know the butt dyno can feel different. But when you actually put them down the track, I can assure you that the 1/4 mile times are going to be within tenths of a second difference (with the 16G perhaps coming out on top), I guess people have a different preference in things. They either want it on the low end, or on the top end. They kinda cancel each other, one spools earlier but falls off at the top, and the other turbo is the opposite, a little later on the bottom end, and pulls harder up top.
2.4L
thats how i decided
2.4L
thats how i decided
yea i have heard that the EL style helps with spool up and the ball bearing DEFINITELY will help ... as far as what rhythmnsmoke said im just going by what ive heard but id definitely like to see that link to check that research out. either way im sure there are LOTS of factors affecting spool. motor displacement, flow, turbo, manifold, DP (exhaust) etc.
Found it.
http://www.turbobygarrett.com/turbob...o_tech102.html
For some reason I thought I read somewhere about the log style spooling faster. I thought it was here, but guess not...
Found it.
Funny it feels like we were both under the ZPI Hocus Pocus Mambo Jumbo VooDoo trance when we read about log manifold advantages
I think I'll hit up Google for log manifold to check...
Blunderbuss
10-08-2015 04:56 PM
crimson_sinn
09-25-2015 09:41 PM
BlingSlade
09-05-2015 08:52 AM
