flames out the exhaust
Old 12-27-2007, 09:52 PM
  #61
06SuperWhite_SoCal_tC's Avatar
Originally Posted by ScionizedRide
Originally Posted by draxcaliber
alright, my friend told me it is when you have alot of backpressure in your exhaust. are you still on stock exhaust? i guess that might be something that contributes.
my friend with an sti shoots out flames and pops with full 3" exhaust
Ya my buddy with a STi has a 3.5" turbo-back and his shoots flames. They rise up above his trunk they're so big.
06SuperWhite_SoCal_tC is offline
Old 12-27-2007, 10:42 PM
  #62
Music City Scions
rhythmnsmoke's Avatar
Originally Posted by Guru
As long as your velocity doesn't slow down appreciably (which it shouldn't on a well designed setup) there should be no downside.
That IS where the problem is. The 3 inch diameter is allowing the exhaust gases to cool to much. Hence loss of tQ numbers for any of the cars with 350 and below whp. Which is pretty much 90% of the cars on here.
rhythmnsmoke is offline
Old 12-27-2007, 10:43 PM
  #63
Music City Scions
Originally Posted by Mr_Meaty
manifold design plays a part as well...el vs. log.
Man, I remember seeing that vid...if that was my dyno, I'd be ____ed! Why the hell would you launch like that on a dyno?
1/4 mile simulation. Some dyno's have it.
Old 12-27-2007, 10:51 PM
  #64
Mr_Meaty's Avatar
hmmm....never heard of it, but I'll take your word for it.
Good enough for me.
Oh, and aen, that topic has been discussed in lenght before. a log style mani is usually shorter so allows for quicker spooling, but the unequal lenght runners caues turbulance, wheras an EL mani (usually longer runners) have a slightly slower spool but the equal lengh runner allow for smooth deliver of air flow to the turbine allowing for a smoother HP/Tq curve and ultimatley, more power, and i beleive HP builds more exponentially then TQ, which is why a good flowing EL mani will produce more HP then TQ after a certain PSI level.
After this.... phil>hieu!
Mr_Meaty is offline
Old 12-28-2007, 12:05 AM
  #65
Bryan06tC's Avatar
Explanation > Ignorance
Bryan06tC is offline
Old 12-28-2007, 09:31 AM
  #66
aen
aen's Avatar
hieu = already knew that, just wanted elaboration to solidify his theories...
i dunno about you but i do recall going at this already, hence the log manifold and big turbo i have. =|
60-1 turbo, 70 trim. benifit from a 3 inch exhaust?
aen is offline
Old 12-28-2007, 10:48 AM
  #67
sciontcnj's Avatar
i dont know how people can say you lose trq...i mean the dynos show that you gain 7 foot lbs as far as i saw
sciontcnj is offline
Old 12-28-2007, 03:16 PM
  #68
Music City Scions
Link? The dyno I saw showed a significantly lower tQ number compared to other tC's running the same boost and HP #'s, but having a 2.5 inch exhaust instead.
Old 12-28-2007, 03:23 PM
  #69
Mr_Meaty's Avatar
Yeah, aen, your larger turbo is compensating for your log mani, but untill we get that dynoed, we won't see exactly where power comes on and what not. And if you switched to an EL mani, you would get more, smoother power.
sciontcnj: we aerent saying that you LOSE tq, you just build more HP then tq. the stock tc motor has a little more tq then hp...turbos with log manis on our motors have higher tq then hp, and those with el manis (with enough psi) have higher hp then tq.
What does any of this have to do with flames out the exhaust?
Mr_Meaty is offline
Old 12-28-2007, 03:25 PM
  #70
sciontcnj's Avatar
not much at all...lol guess i sort of took it off topic
Old 12-28-2007, 06:51 PM
  #71
Bryan06tC's Avatar
and according to Phil's sig .....
aen wrote:
if there was a thread on being offtopic
we'd be ontopic.
in fact i think there is.
but we don't post there...
That is very clever humor!!...lol
Old 12-28-2007, 08:18 PM
  #72
Guru's Avatar
Hmm, well contrary to the generalizations made by a few people I am still getting more torque than HP on both an equal length manifold and 3 inch exhaust equipped car. On top of that it is a relatively large turbo (bigger than most Scion guys run) which in theory should also make less torque and more HP but yet it doesn't. I think it is a difficult thing to generalize these assumptions floating around on this thread regarding exhausts and manifolds. It certainly has gotten off topic though.
Guru is offline
Old 12-28-2007, 08:24 PM
  #73
Bryan06tC's Avatar
I think experience speaks for itself... so of experience is lacking only opinions can be forth... trust what the experience says IMO
Old 12-29-2007, 02:49 PM
  #74
yamaha16bw's Avatar
3 inch exhaust, EQ manifold, GT37 turbo and I have 340whp and 346wtq....
3 inch FTW
I pop flames too. If you watch my youtube video you can hear it pop while shifting in the 60-100 run.
My brother shoots flames out of the QTP cutout which looks hot as hell at night
yamaha16bw is offline
Old 12-29-2007, 03:21 PM
  #75
Blue_TC_Man's Avatar
a lot of turbo cars flame on shifts cause they are alittle rich, evo's are really bad for it since they are pig rich from the factory, but running 10psi u probably have the horsepower to run at least a 2.75-3.0" exhaust
Blue_TC_Man is offline
Old 12-29-2007, 03:39 PM
  #76
Bryan06tC's Avatar
05-06 Tc's peak power point is only 5500 RPM with stock camshafts and compression ratio. 07-08's peak later at 6000 RPM due to changes in the camshaft profile among other minor things. That peak power point changes little but the torque peak can move around on you based on spool up characteristics of the turbine used.
OK so like he said torque moves based on spool characteristics.... so logical deduction says if 3'' allows for spool up more easily then torque peak may move around i.e. come on earlier.... so not less torque but peak torque at a different point
Old 12-29-2007, 03:58 PM
  #77
aen
aen's Avatar
i had flames last night! i finnally had a buddy drive behind me and she thought i was going to blow up. lol.
aen is offline
Old 12-29-2007, 04:57 PM
  #78
Music City Scions
You don't have to be turboed though to shoot flames. N/A vehicles can do it as well.
Old 12-29-2007, 11:19 PM
  #79
olaHalo's Avatar
Originally Posted by aen
how..the hell do you notice flames comming out while you are driving?!
duh when you see the back to the future skid marks behind you
olaHalo is offline
Old 07-13-2008, 09:01 AM
  #80
Racersky's Avatar
lol I know this is old and all but I came across this thread looking for something else. Just wanted to post this vid
http://www.youtube.com/watch?v=qZPZ3...eature=related
Racersky is offline
Quick Reply: flames out the exhaust
