FrozenBoost Water to Air (TW) ***Updated with PICS***
Old 04-09-2009, 12:22 AM
  #41
gompka's Avatar
Originally Posted by thendawg
LOL from what i heard straight water actually has the best cooling capacity so if your like me in Oklahoma its best to run straight water in the summer when it never gets under 32
Its not just about efficiency, the coolant helps keep things from growing in your system, and it also helps the metal in the system from getting mineral deposits etc. You don't need to run much anti-freeze with the water to get these benefits. Anti freeze also boils at a higher temp than straight water.
gompka is offline
Old 04-09-2009, 10:58 PM
  #42
thendawg's Avatar
Very true - maybe i should run like 15% antifreeze in mine - although i plan on adding ice to the resevoir when at the track and what not so itll be getting drained from time to time to let off the excess water
thendawg is offline
Old 04-11-2009, 12:01 AM
  #43
raptorsp123's Avatar
******The Update******
The parts arrived packaged neatly only three days after ordering....
The VBand Clamps/Vband - Solid, Excellent Quality
The Cat Delete - Very Nice Welds, Dynamicly Smooth Test Pipe
2.5" BOV T Pipe for TurboXS Type H: Excellent, My Type H fit perfect
Type 20 LongFlow Water to Air Intercooler w/Adapters - Welds look much better than I expected, Low Pressure Leak Test revealed no leaks
Bousch Water Pump (Cobra) - Have not yet tested, yet arrived with Universal Harness
Raditor (Heat Exchanger) - All fins are intact, inlet/outlet adapters look slightly stripped
Fan
JUST FOR FUN: My TURBO
t3/t4 Turbocharger (Garrett 63 Trim w/ Stainless Steel Braided Oil Lines
Powder Coated Turbine Housing
Further Updates in the Future. Let me know what you all think! I will be conducting high pressure testing, leakdown testing, as well as further testing in the future . Just thought I would post this now...
raptorsp123 is offline
Old 04-11-2009, 12:05 AM
  #44
Sorry about the image sizes. Was in a rush at work. Just click on the pictures if you want to see greater detail!
Old 04-11-2009, 12:19 AM
  #45
Ronin Scion
Ace83's Avatar
looks great, cant wait to see it installed
Ace83 is offline
Old 04-11-2009, 06:51 PM
  #46
gompka's Avatar
how thick is the fan? and the radiator is 1" thick right? Anyone know exactly how much depth there is to work with in the lower grill area? 3"-4" ?
gompka is offline
Old 04-11-2009, 11:14 PM
  #47
showstoppatc's Avatar
Do you have a condenser?
showstoppatc is offline
  #48
Old 04-12-2009, 05:58 AM
  #49
The heat exchanger is 2" thick without the fan. The fan is 2.5" thick at center. I think we have enough room...I still have the condenser, radiator, and now the heat exhanger!
Old 04-12-2009, 01:59 PM
  #50
extremely tight fit with the condenser..
you still have the crash bar?
Old 04-13-2009, 02:45 AM
  #51
Yes I still have the crash bar. The heat exchanger and the fan will still fit. I am however, trying explore mounting options...
Old 04-13-2009, 10:31 AM
  #52
pics?
I am using a 95 civic radiator in my setup .. I had condenser and crash bar already removed but I doubt it would have fit
but my fittings come out towards the back of the rad not up like your rad
Old 04-13-2009, 02:38 PM
  #53
I have not yet done the install, just merely recieved the parts. A 95 Civic Radiator is much larger than the one that I am using. Fitment is much easier since my heat exchanger is 10X13.
Old 04-14-2009, 01:45 AM
  #54
crush02342002's Avatar
parts look good....
crush02342002 is offline
Old 04-14-2009, 04:05 PM
  #55
gompka's Avatar
how's the quality of the fan? Have you hooked it up? I'm wondering how loud it is. Also are you gonna be using a temperature switch with the fan?
gompka is offline
Old 04-15-2009, 02:59 PM
  #56
I haven't hooked anything up yet officially, and will attempt a mock install this upcoming weekend...will let you know about the fan. I am not sure yet about the temperature switch...looking into some other options!
Old 04-19-2009, 03:47 PM
  #57
fans are good quality and are very quiet.
  #58
Old 04-19-2009, 03:58 PM
  #59
chicotunner07's Avatar
everything looks great!
that water pump looks like a supercharger, lol
chicotunner07 is offline
Old 04-19-2009, 04:48 PM
  #60
gompka's Avatar
lol it is a "centrifugal" water pump ;) its pretty beefy 6gpm
gompka is offline
Quick Reply: FrozenBoost Water to Air (TW) ***Updated with PICS***
