FUEL PUMP HELP!
The STI pump is GSS342 here is a link to it.
http://importimageonline.com/product...roducts_id=541
Also why do i need supra install kit if i am just goin to hard wire?
Question again.
I just got my walbro 255lph fuel pump.
Anyone know what the dezod install kit consists of???
I believe it might be the supra clip. If so where can I get one?
They won't sell me the install kit alone, which sucks.
Originally Posted by bluesciontc
Just hard wire it or modify the clip (thats what I did) cut the wires and pull the old ones off of the stock pump and wire it up.
Any other recommendations??
Do I need to solder any of it? or just wire tap it?
Will I need any sealant? or plumbers tape? for the job.
Thanks for the help. Really appreciate it
I would def solder everything in there. The fuel pump is your life line. Teflon tape is not needed, sealant is also not needed. The port to get to the fuel pump has some really stick crap on there from Toyota and will reseal it self. Pretty much all I can say is take your time and make it very very nice no loose ends.
I also recommend the use of heat shrink,Def use that on all soldered connections.
No problem man any time.
WOW.
Did you just put a screw and jb weld in that oil hole? once you removed the harmonic balancer (I think thats what its called).
Also, aren't you afraid the screw and jbweld will come out with all the engine vibration??
Do you think I can do it, by just have the front end of the car jacked up???
Yea we did it to my friends tC last week. It takes 24 hours for the JB weld to cure so the oil pan has to be off for 24 hours. The screw and JB weld won't come out at all. There are actually a couple threads on this forum about removing the balance shafts.
steeze69
05-24-2021 02:57 AM
