Fuel Rail spraying out of cylinder 1
Old 01-07-2008 | 04:30 AM
turbotc06's Avatar
OMFG im so ____ed i am so mad ...
ok so i dont have to pull the motor apart but i gotta reline up my crank shaft and cam gear marks and then turn the crank shaft notch to the 0 degree mark on the timing chain cover and BOOM
fixed
an hours worth of work!
Old 01-07-2008 | 08:11 AM
reign's Avatar
Yea you won't bend valves with our engines. They're of a non-interference design 8-) Go toyota
Old 01-07-2008 | 09:18 AM
aen's Avatar
aen
how do you do that?
just out of curiosity how do you reline the crankshaft and all that crap?
Old 01-08-2008 | 12:05 AM
turbotc06's Avatar
way to go! intake manifold gasket is blown and there is like a 2 centimeter gap between the block and the intake manifold ....thats why she is running so high and rich
oh man takes 5 minutes to find a problem when you think about it
Old 01-08-2008 | 11:26 PM
turbotc06's Avatar
ok well iit runs for about 3 seconds and quickly dies off right after that
fuel is on the tops of the pistons and the plugs are wet
timing issue you guys think??
Old 01-09-2008 | 12:37 AM
Mr_Meaty's Avatar
What manifold and engine management are you using?
Old 01-09-2008 | 07:12 AM
turbotc06's Avatar
greddy ultimate and i have zpis headers
my neighbor thats a like 35 year mechanic thinks it might be the timing 180 degrees out which would mean were firing on the exhuast stroke instead of the power
hopefully after it stops raining tomorrow me and him can fix it
starting to see the light at the end of the tunnel!!!!
Old 01-13-2008 | 10:32 PM
turbotc06's Avatar
ok so we fixed the timing on her
plugs no longer foul up
she goes through the start sequence and then after that she revs to like 3k rpms and quickly shuts off
any ideas?
gedster314
14
11-17-2018 03:56 PM
brett561tc
09-15-2015 07:33 AM
mw1957
07-28-2015 07:04 AM
mw1957
07-28-2015 06:31 AM
boxcar87
07-12-2015 01:16 AM
Quick Reply: Fuel Rail spraying out of cylinder 1
