fuel solonoid got stuck open
Old 09-13-2009 | 10:09 PM
SiL3nTKiLL's Avatar
Default fuel solonoid got stuck open
my fuel solonoid got stuck open and fuel poured into my intake when i was starting my car...it all dripped out from the filter, but now my car doesnt start...i fixed the solenoid but it still wont start....anyway to fix this or should i take out the intake, dry it out, wash the filter etc..? there was some brown liquid (assuming oil) near the driver tire area, but i couldnt find wher it came from, and when i try to start the car, there is a bad smell...any ideas?
Old 09-13-2009 | 10:53 PM
Ace83's Avatar
Ronin Scion
what mods do you have? why did this happen? just take it to a mechanic if you dont know what you're doing.. it involves fuel, got to be careful your car could burst in flames
Old 09-13-2009 | 10:59 PM
SiL3nTKiLL's Avatar
its from the nitrous and i allready fixed the fuel solenoid...i know what the problem was, it was the fuel spitting into the intake while starting the car...if u read my question, it was asking if i just let it dry or do i have to do something else...i know what im doing and the only other mod i have is the intake.
Old 09-13-2009 | 11:24 PM
thendawg's Avatar
Fuell will evaporate rather quickly - id recommend disssasembling the intake, cleaning the maf sensor with electronics cleaner (you stated fuel made it all the way to the filter so im assuming it go on the maf sensor), clean out all the intake piping - while youre doing this use a screwdriver to "prop" open the throttle body to allow any fuel in the intake mani to evaporate - id leave it propped open for 30-45 min. Than reassemble the intake, reset the ecu by d/c the battery for 20 min, than reconnect the battery and try to start the car
Old 09-13-2009 | 11:36 PM
Go4shoped's Avatar
remove the spark plugs and crank the motor over a couple of times. check the plugs to see if theyre fouled. clean maf, dry intake and filter, reassemble, and try to start it. you might need to give it some gas to get it started.
Old 09-14-2009 | 12:03 AM
cburglb34's Avatar
do this...
and also when u go to start it have the gas pedal fully pressed to the floor
had to do this one day when my old turbo setup flooded my motor
Old 09-14-2009 | 12:16 AM
SiL3nTKiLL's Avatar
car starts, but a ton of white smoke came out of the exhaust, and still smoking a bit....but any idea why this smoke hapened? and what could cause that oil leak (which i duno where it came from)
Old 09-14-2009 | 12:44 AM
ecko04's Avatar
Oil leak? You never said anything about an oil leak. Oil would burn bluish.
Simple, fuel solenoids have mechanical parts, like everything mechanical they are prone to failure. There should have been another precaution with the solenoid but i'm sure you're using a Zex, CHEAP, which would speak for itself. You need to be careful, I recommend using Ny-trex or NX fuel and nitrous solenoids to get rid of those Zex components.
Old 09-14-2009 | 02:08 AM
SiL3nTKiLL's Avatar
lol i am using ny-trex....and i did say the oil leak...if u read the original post it says about the brown fluid which im assuming is oil...
k1114
43
03-01-2023 04:08 AM
anti_virus347
04-03-2015 06:17 PM
GetSlideways
Scion xD Drivetrain & Power
03-17-2015 12:30 AM
yhwhdesign
03-07-2015 03:01 AM
eric_m
79
03-17-2013 01:21 AM
