Full build thread....TONS of pics!
Old 05-24-2010, 02:06 PM
  #141
yamaha16bw's Avatar
Originally Posted by brett561tc
just trying to see what your tunner considers knock. anything below 1 volt is just engine noise. numbers seem right on for 13 psi. if knock retard was pulling timing then it shouldnt have made those numbers at 13 psi. what were your afr's?
well just spoke to my tuner...
He said that my motor was alot more quite then other tC motors to start with. The problem was that right around the 5500rpm range Id get a jump in knock volts like .7-1volt instead a nice curve in knock volts due to engine noise.
yamaha16bw is offline
Old 05-24-2010, 02:19 PM
  #142
brett561tc's Avatar
you should be able to change the parameters of the knock retard to add fuel and pull timing based on voltage. if the engine is noisier than most, just set the knock retard at 1.2 volts and tune away. see what i does with a fresh tank of gas first before changing the settings though.
brett561tc is offline
Old 05-24-2010, 02:20 PM
  #143
yamaha16bw's Avatar
Yea i think thats the plan. I will keep you posted.
Old 05-24-2010, 02:23 PM
  #144
brett561tc's Avatar
good luck bro. for sure one of my favorite builds for a while now.
Old 05-24-2010, 03:05 PM
  #145
Scionetics
KAD
paul_dezod's Avatar
Knock voltage threshold can vary from vehicle to vehicle due to harmonics from rotating assembly removal, the individual turbo setup etc. You need to make sure you do a full RPM pull with conservative timing and enough fuel to guarantee there is no knock and establish your individual knock profile then proceed accordingly.
paul_dezod is offline
Old 05-24-2010, 03:24 PM
  #146
ElevationTC's Avatar
in the 4500-5k- Range You do need to pull more timing.
ElevationTC is offline
Old 05-24-2010, 03:47 PM
  #147
Scionetics
KAD
paul_dezod's Avatar
Why do you say Mike?
Old 05-24-2010, 03:50 PM
  #148
drivexB's Avatar
I youtubed "scion turbo" and your video came up haha
your car is friggin' awesome
drivexB is offline
Old 05-24-2010, 03:58 PM
  #149
06sciontcnda704's Avatar
im sorry if you already told us but what turbo is that thing looks huge ???
06sciontcnda704 is offline
Old 05-24-2010, 05:33 PM
  #150
Team Scionara
skinnayyy's Avatar
gt 37-35 hybrid.
skinnayyy is offline
Old 05-24-2010, 05:48 PM
  #151
Out of the 4 scions ive tuned using ur 1050 box, ive always had to taper timing off to prevent knock.. in that range.
Stock ecu also switches timing from 19 degrees to 15 degrees at this point..
Im asuming it has something to do with vvti.
Old 05-24-2010, 06:30 PM
  #152
yamaha16bw's Avatar
We tried pulling the timing alittle and still got alittle knock in the same range.
It could be so many things so we are just going to take it one thing at a time. Gas being the first.
Good part is the engine ran really really good till that point. I was alittle nervous getting on the dyno after all the time and work i put into it I just didnt want anythign to break and nothing did.
Another thing i was thinking is maybe it was starting to heat soak alittle bit. Started knocking on like run 15-17 and it was hot a humid plus the alum. intake mani. That prolly will prolly add to the heat soak.
Keep the thoughts coming if anyone else thinks of something....
Old 05-24-2010, 06:33 PM
  #153
17 pulls? How long were you letting it cool down for? I pray to god u didint make 17 back to back :O
Old 05-24-2010, 08:02 PM
  #154
Team Scionara
skinnayyy's Avatar
haha i think in the end we did about 22 pulls? but we would do a pull, crank up the heat and wait a couple minutes in between so it wasn't technically right after the other... but not a giant wait.
Old 05-24-2010, 10:06 PM
  #155
Flintmica2006's Avatar
Ya i think we let it sit for about 5-10 mins between runs with the fan on high the heater on max.
Flintmica2006 is offline
Old 05-25-2010, 01:49 AM
  #156
yamaha16bw's Avatar
the car was getting alittle hot. but we let it sit for alittle bit every so many runs.
Prolly could of waited alittle longer but we were pressed for time.
Old 05-25-2010, 02:52 AM
  #157
SilverCFtC's Avatar
Hey Ben, was the Xa Toms? Did he finally get it running?
If you need that gas burned off I can play hookie from work tomorrow.
-Sean
SilverCFtC is offline
Old 05-25-2010, 12:57 PM
  #158
yamaha16bw's Avatar
lol Toms xA made 170 but i forget how much psi.
Old 05-25-2010, 02:27 PM
  #159
Team Scionara
skinnayyy's Avatar
it was about 10-11 psi for his final run.
Old 05-25-2010, 03:19 PM
  #160
Scionetics
KAD
paul_dezod's Avatar
Was a proper car specific knock curve established by you in AEM Pro?
That knock there could be engine harmomics and/or setup rattles and such that triggered the knock sensor, which I have seen a few times.
In all, if it was knock, then the setup or fuel & ignition should be addressed. Either run a richer AFR or less timing. One way or the other you need to slow down combustion. Simple as that. If you still can not control the det, then a higher quality fuel, more efficient turbocharger, more efficient intercooler should be addressed for the power goals and use of the car.
With respect to your timing comment, at what boost level have you observed this? What where the peak EGTs?
Just note that I am not trying to have a pooping match with you, just simply keeping everything 100% factual and educational for the community.
Quick Reply: Full build thread....TONS of pics!
