The fun begins! Fmic Setup with supercharger
Old 07-28-2008, 08:24 PM
TokenAsianGuy's Avatar
I've been waiting for a thread like this for a while!
TokenAsianGuy is offline
Old 07-28-2008, 09:07 PM
Old 07-28-2008, 09:12 PM
jwaggz82's Avatar
^ do a long search and you should find a few other people. Im positive there were some .... one guy that had a fmic and one that had an air/water ic
jwaggz82 is offline
Old 07-28-2008, 09:35 PM
2_much_tc's Avatar
the one with the air water was the guy who was sponsored by ZPI, and the one with the Bell intercooler was from the Bay area. I know that won't help much...
2_much_tc is offline
Old 07-28-2008, 09:42 PM
jwaggz82's Avatar
Ha - zpi
jwaggz82 is offline
Old 07-28-2008, 11:41 PM
ElevationTC's Avatar
Just waiting to get some more pipping... Slow old UPS.
Been thinking of going Full standalone also! the tempation of credit cards
ElevationTC is offline
Old 07-29-2008, 12:09 AM
Shoob's Avatar
no kidding right.. lol
Shoob is offline
Old 08-04-2008, 11:49 PM
mattieg's Avatar
any more updates... im not letting this thread die
mattieg is offline
Old 08-04-2008, 11:59 PM
highvoltage1's Avatar
oh snap i forgot about this. Yea any updates??
highvoltage1 is offline
Old 08-05-2008, 02:23 AM
Just waiting on some free time, to get it all together. plus my pully from NST is not here yet! custom order!
Old 08-05-2008, 02:30 AM
andino's Avatar
Looks promising. Can't wait to see the end product man. Props for going out and doing this yourself
andino is offline
Old 08-05-2008, 02:34 AM
eminence's Avatar
cool, looks good so far. you can run the 12psi pulley if u have a pressure drop of 2psi. it will run safely on the trd map. i've been running it like that for over 10k miles and it is very efficient. its beastly!
eminence is offline
Old 08-05-2008, 11:41 AM
jwaggz82's Avatar
You can no way in hell be running ok with a 12lb pulley and your trd map. 9.5 has been tested many times to be the 100% max. Even the 10's that were made when the places were doing their R&D reported as being too high for that tune. If you really are running a 12lb on the trd map I would switch it out, buy management (eman ultimate)/harness - and get turned before somethting happens to your engine.
jwaggz82 is offline
Old 08-05-2008, 12:13 PM
He has a pressure drop of 2 pounds with the intercooler piping? So there for he is running 10 pounds which being intercooled will run fine!
Old 08-05-2008, 05:09 PM
B_Real45's Avatar
Is this so called 2lb drop a fact or an assumption?
B_Real45 is offline
Old 08-05-2008, 06:16 PM
m6ar2cel6oTC's Avatar
what size is the 14 psi pulley? 50mm?
m6ar2cel6oTC is offline
Old 08-05-2008, 07:32 PM
mattieg's Avatar
there was a gentlemen who actually tried this out before on his car with a FMIC. I believe it was actually tested as a 2 psi drop. But unfortunately he could not finish the project.
mattieg is offline
Old 08-05-2008, 07:44 PM
eminence's Avatar
it is a fact. i lose 2psi through the fmic. you can argue all you want about the issue.
eminence is offline
Old 08-05-2008, 10:53 PM
BuddhasTC's Avatar
it's not a fact...but in most cases it has happened. There was a handful of people on here at least that have gotten a FMIC with s/c...and most saw around 2 psi drop...but one was only slightly over 1 psi drop...not a fact, but there is a drop in psi
BuddhasTC is offline
Old 08-06-2008, 12:08 AM
jwaggz82's Avatar
^there are very few ways that you can change the shape of the piping (since there is very little space to begin with) so you know you will loose atleast 1lb and I would bet it would be 2lbs.
jwaggz82 is offline
Quick Reply: The fun begins! Fmic Setup with supercharger
