Get more power but still pass visual inspection and SMOG?
Hi folks,
I thought I'd just brainstorm with ya'll. What kind of mods would you do to your engine if you wanted to still pass visual inspections AND smog. I/H/E is out (naturally). It's got to be sneaky. I'm guessing changing the engine internals. The ony things I can think of are;
TRD Supercharger
lightweight / underdrive pulleys
Port and polish
I can't really think of anything else... Hmm maybe bore out the block a bit more for more displacement? I dunno.
TRD Supercharger
Port and polish
zpi stage 1 head, header is not out...just conceal it with a custom mount to mount the stock heat shield over it, exhaust is not out if you keep the 2nd cat in place, S/c, P&P, blueprint the block, standalone ECU, pulleys if it's concealed, let's review...
1. ZPI stage 1 head
2. Header concealed under stock heat shield
3. Catback Exhaust
4. Standalone ECU
5. Pulleys
6. S/C
7. P&P
8. Have the block blueprinted and up the compression ratio
1. ZPI stage 1 head
3. Catback Exhaust
4. Standalone ECU
5. Pulleys
6. S/C
7. P&P
In theory, maybe. IF the guy isn't paying attention. If he doesn't know what he's looking at. Do you have a O2 sensor in there somewhere?
ZPI stage 1 head
Have the block blueprinted and up the compression ratio - I assume you mean have the whole block re-made? With a longer draw? Won't that make the block too tall? I guess there might be some room to futz around. You could also bore out the block instead and put in bigger piston heads too.
ZPI stage 1 head
Originally Posted by Mr_Meaty
But if they don't do a visual, anything that keeps the CEL off and a high flow cat should pass smog, right?
ZPI stage 1 head
ZPI stage 1 head
you telling me that no one with a turbo is getting a smog check?
Someone feel free to correct me if I'm wrong...
I'm talking specifically about passing visual inspection AND smog... So a forced induction setup won't work unless you can make it invisble. (aside from TRD supercharger)
Hmm, if you do increase your compression ratio, what happens to your level of pollution? I would assume your cat would have a shorter life. Does CARB measure concentration or qty? I"m guessing it's Parts Per Million.
Godfryness
01-03-2015 12:18 AM
crystaljukebox_com
02-05-2004 06:53 AM
