Getting AFR reading on computer?
Originally Posted by gompka
If i'm not mistaken there is a folder made in your fi/c software directory, when you install it on your computer which tells you which wire of the fic to hook up to the blue wire of the uego. I know 100% i read it either there or on the aem forums. Its just a one wire hook up, aem uego data to aem fic aux. I don't have it infront of me i'll see if i can find it tomorrow
correct...ther is a pdf file on your computer that was downloaded along with the fic software......but finding it on some computers can be a pita....or maybe i just have a fubar computer
as far as wire color on the uego i thought i read it was white......i wonder if older uego's used a different color.....i mean it is possible.
so far what i have gathered....
the wire coming FROM FIC is a brown wire (18th pin) labeled Aux In on the 22 pin connector(thats if you are using the harness that came in the box with the fic)
if you are using a pnp harness that wire will prolly be missing, in this case all you need to do is get the universal harness and compare it to the pnp harness. find the aux in wire and see if you can pull it out of the universal connector and put it in you pnp harness.
FROM THE UEGO....your looking for the white wire....not hard to find...lol
so you take the Aux In wire comeing from the Fic and connect it with the white wire coming from the UEGO
next you will need to set up the fic to read your uego properly.
open up the fic program, look up to the tool bar and click on setup, scroll down to Aux Gauge and click it. This is wher you will need to set up max afr and low afr...stuff like that.
ill try and get it done today.
ok i got some pics but im not really prepaired to do a full write up or anything, iv been pretty busy.
btw please dont give me too much crap about how i have my resisters...just havnt gotten around to doing it right.
so here is the universal harness (22pin connector)
heres the aux in wire that you need
another shot of the wire
for thos of us that are using the pnp harness this is the location that the aux in wire is supposed to be
so if your 22 pin connector doesnt have that wire then you need to get the universal connector and pull out that wire
now you can insert it into your connector on your pnp harness
like i said you will prolly need to pull a wire from your universal harness (preferably the wire labled as Aux In) and insert it into you pnp harness...then take that wire you just inserted into your pnp harness and connect it with the white wire coming from you UEGO
just to clear it up. using the last picture as reference. i would have to run the white wire into the port in which your brown AUX wire is.
j/w did this acctually work. you got a AFR reading?
i left all my butt splices and wires at a friends house so i didnt get to finish, also had my little girl to deal with so yeah i couldnt hardly do anything....just had enough time to show you guys what i am going to do as per aem's instructions. Im positive it will work though, but we shall see.
has anyone done it yet? If not i am going to try my best to do it this weekend....I have one major problem and its that i dont have a laptop handy so if no one in the greenspoint area or Houston for that matter wouldnt mind coming by my house for a few mins who has a laptop then ill have to wait till sunday so i can borrow my cousin's. So far iv been able to get away with not having one but its getting to be more and more pressing that i get one. Im also going to look into setting up the fic to datalog if i have time. Iv been extremly lucky that iv been able to get as far as i have without all this stuff but now its a must.
getting it to data log is easy. i would try it but my car is parked for the winter and covered in snow.... :-( i really wish this winter would be done already so i can drive my car again!!
ok i went ahead and rigged up the datalog and uego.......IT WORKS!!!!!!!
but i only got close to 2 seconds of log....i set it for 100ms
but i was able to get a reading and graph it all with aempro (logger)...so i know that the uego is hooked up correctly......im soooooo going to have fun with this stuff now...hehehe
time for a damn near perfect street tune!!! this can't be the first time someone has done this... if so how do ppl street tune with out knowing thier AFR's? unless you look at your gauge all the time.... WTF?
they prolly been doing what iv been doing......one person drives while the over holds a laptop......hahaha
i was wrong about the setting though (100ms) i think what i did was set my tps too high and when i let off the throttle it ended the logging session....oops
ill prolly be cleaning up the wiring tomorrow and do so-more logging......i got wires effing everywhere...lol
Originally Posted by Carlanga
hey crush, if u need a hand just let me know, I need to start training on the FIC . I don't work till next Monday anyways
i got a problem, at first i thought i was logging the uego cause i only got 2 seconds of data and the uego said 10 which i know that under full throttle and 1-2psi of low boost is normal for my fuel map.....but i have gotten a couple of logs and i know that they all couldnt be reading 10afr, so iv come to the conclusion that either i have a lose connection, mixed up the wires from my gauges (all aem gauges have a white wire coming from them, that iv noticed...lol), or the directions i got from aem are a little off. I say off cause on the wire you ground to datalog aem tells you that its labeled one thing but ends up being another.
Ill try the blue wire just to see as well as all the other white wires.
i could have possibly not set it up correctly, but then again i went by the manual
