Gompka build - Running great!
Old 04-04-2010, 02:28 AM
  #141
crush02342002's Avatar
Originally Posted by brett561tc
do you have the resistor mod for the fic?
good call...
crush02342002 is offline
Old 04-04-2010, 02:39 AM
  #142
GQQSE13's Avatar
glad to see it all coming together
GQQSE13 is offline
Old 04-04-2010, 02:41 AM
  #143
ElevationTC's Avatar
large clreance somwere, oil thins out when warm, oil pressure drops lower knocking happends.. switch to 10w40 or 20w50 and drive.
also send me ur fic map...
ElevationTC is offline
Old 04-04-2010, 06:35 PM
  #144
B_Real45's Avatar
I agree with Mike it's a tolerance issue.
Brett - piston slap is more noticeable in cold engines - when the pistons warm up, they fill the cylinder better and there is less slap. Gompka is experiencing the opposite.
B_Real45 is offline
Old 04-04-2010, 06:54 PM
  #145
Ronin Scion
Ace83's Avatar
thats gonna suck having to open up the motor.. well i hope its less than that
Ace83 is offline
Old 04-04-2010, 09:33 PM
  #146
Carlanga's Avatar
the hesitation issue sounds to be tuning related. I had a similar problem between 3-8psi and 3000-4000 rpm. It was just that the fuel map blocks around that area were a bit too rich and it was pulling fuel on me. For some reason it was more noticeable at part-throttle. It feels like when the fuel level is almost at empty and I attempt to take hard turns or wot from a dig, it just cuts fuel on me.
Carlanga is offline
Old 04-05-2010, 02:03 AM
  #147
gompka's Avatar
That might be it for the hesitation, but the knocking I still have to figure out.
http://s49.photobucket.com/albums/f2...t=FILE0001.flv
gompka is offline
Old 04-05-2010, 02:09 AM
  #148
good grief you were not lieing about the knock
Old 04-05-2010, 02:13 AM
  #149
gompka's Avatar
I think the camera makes it sound extra loud, but it is pretty loud. I'm gonna check some things tomorrow to try to narrow it down before I take the motor out and crack it open. No more starting it for now I think, don't want to cause some catastrophic failure, whatever it is, it seems fixable.
gompka is offline
Old 04-05-2010, 02:19 AM
  #150
brett561tc's Avatar
do your fans come on at the same time the knocking starts? the noise doesn't begin gradually, it's very all of the sudden. im thinking it may have something to do with the thermostat or water pump.
brett561tc is offline
Old 04-05-2010, 02:49 AM
  #151
trd07tc's Avatar
extremely odd that the noise comes on that suddenly like its switch activated
maybe do another vid but give it some throttle so we can hear the noise in correspondence with RPM
trd07tc is offline
Old 04-05-2010, 02:51 AM
  #152
gompka's Avatar
engine temp is normal, right in the middle of the gauge. The knock follows rpms, gets faster with more rpm and slower with less.
gompka is offline
Old 04-05-2010, 03:01 AM
  #153
trd07tc's Avatar
does it happen exactly when it reaches normal operating temperature?
do you have a scangauge?
trd07tc is offline
Old 04-05-2010, 03:02 AM
  #154
brett561tc's Avatar
so then the noise doesn't start simultaneously with the fans?
Old 04-05-2010, 03:08 AM
  #155
trd07tc's Avatar
did u drop the oil and check it out?
trd07tc is offline
Old 04-05-2010, 03:16 AM
  #156
t_urbo_C_harged's Avatar
that's very strange that it just comes in all of a sudden. Do you have a stethoscope? That way you can narrow the location of the noise down. Most anything else I am thinking of would constantly be making noise. Do you have an oil pressure gauge? If so, what is it at? Or does your red oil light come on when the noise occurs? Hope it is something easy/cheap. Sorry to hear this bro!
t_urbo_C_harged is offline
Old 04-05-2010, 03:19 AM
  #157
also, does it run any differently once the noise appears? Do you have any datalogs on the knock sensor?
Old 04-05-2010, 03:31 AM
  #158
gompka's Avatar
Doesn't run any different once the noise kicks in, oil is clean, no check engine or any other light. I'm going to check the oil pressure tomorrow and if its low i have a spare oil pump i can try, if that doesn't do it, engine is coming out again i guess. Just wish I knew what it was so I can be prepared for the fix.
gompka is offline
Old 04-05-2010, 03:51 AM
  #159
cmcpride's Avatar
Default Noise possible vvti
Check your vvti gear. If I'm not mistaken it activates between mid rpm and once engine hits normal operating temp..
cmcpride is offline
Old 04-05-2010, 03:55 AM
  #160
cmcpride's Avatar
May or may not set codes.
cmcpride is offline
Quick Reply: Gompka build - Running great!
