GReddy e-Manage Ultimate or AEM F/IC ?
Old 06-01-2009, 10:41 PM
scikotictc232's Avatar
Default GReddy e-Manage Ultimate or AEM F/IC ?
OK in a few weeks I plan to start saving up money to finish my turbo set up. I will be buying parts as I go a long and hopefully finish soon. I have came to a hard decision though. I have a GReddy ProFec B-spec II boost controller I also have the GReddy support tool and Turbo timer.
Would it make sense to go with the ultimate than over the AEM F/IC I was originally planning on going with ? would my boost controller work better with a GReddy computer or AEM ? I am still learning about this so sorry for the noob question.
Thanks.
__________________
scikotictc232 is offline
Old 06-01-2009, 10:43 PM
nlataille18's Avatar
i like my AEM. I like how i can somewhat partial throttle tune.
nlataille18 is offline
Old 06-01-2009, 10:48 PM
whats up with the partial throttle boosting ?
Old 06-01-2009, 10:59 PM
gingles's Avatar
Just take out your O2 sensors and you can partial throttle boost everywhere and I have the Ultimate.
__________________
gingles is offline
on the e manage your tune works when your at WOT only, With the AEM you can set your throttle position as to when the tune starts to take over (to a certain degree)
Old 06-02-2009, 12:04 AM
gingles's Avatar
Like I said on the Ultimate you can take out your O2 sensors and have full capability over the map. I'm getting 31mpg now.
__________________
gingles is offline
Old 06-02-2009, 12:16 AM
jsg93085's Avatar
Originally Posted by gingles
like i said...on the ultimate you can take out your o2 sensors and have full capability over the map....im getting 31mpg now
right, but not everyone wants to see that CEL...
jsg93085 is offline
Old 06-02-2009, 12:26 AM
RichTc's Avatar
Do you just take the O2 sensor out of the down pipe, or do you remove the sensor completely?
I've read some mixed opinions regarding that route but am very interest (as I run Ultimate).
____
RichTc is offline
Old 06-02-2009, 12:30 AM
I don't care bout the CEL as long as it won't harm my motor. I wanna run two boost settings an 8 psi and a 12 psi tune on stock motor.
Which one will the car run better with? AEM or GReddy ? I know the Ultimate is closer to a full standalone but I also hear a lot of good things about the AEM F/IC.
__________________
Old 06-02-2009, 12:31 AM
gingles you gonna run ur new set up with the ultimate ?
Old 06-02-2009, 12:36 AM
gingles's Avatar
scikotic I will be using the e-Manage Ultimate with my built motor. That is until I get enough money for a Hydra but there is nothing wrong with running a built engine on Ultimate.
I have no O2 sensors and a blow thru MAF setup and love it. My roommate with a standalone always says i have a good setup for the price i paid (around 600 bucks)
__________________
gingles is offline
Old 06-02-2009, 12:40 AM
any one know anything bout the profec b spec II ?
Old 06-02-2009, 12:49 AM
gingles's Avatar
i have that as well scikotic......i love it.......id either get that or a blitz dual solenoid. ...i have one set at 10 psi and 16 psi with 17 psi boost cut.
gingles is offline
Old 06-02-2009, 06:26 PM
CarbonXe's Avatar
0 issues with my F/IC, no CEL even without an anti-fouler.
CarbonXe is offline
Old 06-02-2009, 06:45 PM
gingles's Avatar
carbon, Are you running with no O2 sensors?
__________________
gingles is offline
Old 06-02-2009, 06:47 PM
CarbonXe's Avatar
No, I'm running with both and no cats. I honestly have no idea how I'm not throwing the cat efficiency code.
CarbonXe is offline
Old 06-02-2009, 07:31 PM
gingles's Avatar
oh ok that cel.....i had no cats when i was n/a and never threw a code for it
gingles is offline
Old 06-02-2009, 07:37 PM
CarbonXe's Avatar
Dunno, I've seen people throw it and then solve the problem with an anti-fouler.
The only code I've thrown has been P0500, which is for a VSS, and that's from my In-dash nav unit, it has nothing to do with the turbo.
I like my F/IC, it does what I needed it to do.
CarbonXe is offline
Old 06-02-2009, 07:43 PM
Scionetics
KAD
paul_dezod's Avatar
Indeed
paul_dezod is offline
Old 06-02-2009, 07:45 PM
topekatc's Avatar
If your looking for the AEM F/IC let me know I have one.
____
topekatc is offline
Quick Reply: GReddy e-Manage Ultimate or AEM F/IC ?
