GReddy e-Manage Ultimate or AEM F/IC ?
#41
Originally Posted by scikotictc232
travis how do you like messing with the greddy ult ? I plan on having a pro tune it and then messing with the two step and all that isht myself IF I WENT THAT WAY. not sure yet both sides seem promising.
PS....2 step at 4k rpms is very intimidating.
#42
you can say that again... haha just kidding. ya ill look more into it. drag is probably what I want to do with it right now and mess with autocross and ta more after school.
#44
There is no need to run both a pressure sensor and a Wideband input, as the two maps have different functions with the Ultimate. You are not suppose to run both with the Ultimate. For the PS...used to tune off of boost instead of throttle. For the Wideband input, simply for Auto tuning. Where you can just plug what you want the A/F ratio to actually be at Set RPM's. It also states that you should use this for preliminary tuning, and then fine tune using the other maps, not run them both.
i use the wideband plug into my emanage so i can tune by myself.....i like to datalog and see my afr's in my datalog along with my pressure
#46
Need a lap top regardless. You can run the Wideband setup and simply plug in numbers. Like if I want the car to be at 11.5 A/F ratio at 5000 rpm, then I simply type 11.5 and it's done.
But yeah, lap top for sure.
#48
hey rhythm.....be careful with the af target map because you need the parameters set almost perfect....if not you can get some major over correction and run supper lean or supper rich.....the best thing i did was manual do it to where i was running like 10.5 afr's and have the af target map do very little adjustments at a time....it takes longer but is deff safer.....also you mention hookin up a boost solenoid.......i think your talkin about the profec eo-1 that mounts on the dash right? and not just a projec b spec 2?
#49
^^naw, not the profec's. A Boost solenoid, the profecs are boost controllers.
I will just mess with the AF target map a little bit, nothing to crazy. I want Toan from PTuning to tune up my Ultimate for me. About a 10hr drive just to get tuned...
#51
#53
Where have I ever implied I have hundreds of hours tuning? Like I need to be a tuning expert to be able to tell which system is better....give me a break, it aint Rocket Science.
#54
i tried fooling around with the af target map some.....not a big fan....i prefer to just drive around and tune that way....i have my buddy tuning when im daily driving and most of the time i tune boost by myself through datalogs. tuning is really not that hard you just have to know what all the variables do.......as don from dezod said.......theres a good tune and a bad tune.....no moderate.....i love my setup......14.7 afr everywhere and the slowly start to get rich in boost.....i use the vehicle speed map for the daily drivability and for load tuning.....my next step is to work with the airflow maps........i still say emanage FTMFW
