GReddy e-Manage Ultimate for Scion tC..
#43
well im not, If I was I'll find someone else
btw how long should it take for a Competent shop to install a GReddy Ultimate in a car???
because 8 hours for a RE-WIRE and soldering, 8 hours seems pretty off to me. (they wired it b4 the tune and b4 it messed up)
one other thing. how can you tell if its the injectors arent maxed out yet and is the pump. and vice versa.
#44
I'm telling u dude, get Dezod on AIM and he will tell u everything with DETAILS. They know almost everything about the tC. I really recommend it. Not enough ppl here have entered this thread to have the correct info. I'm trying my best to help u, but I'm no expert yet. So.. :D
#45
OK, I got my car back today.........they said my A/F ratio is........18:1..............
that's they lowest they said they could go. last Thursday it was 12:1 I don't know what happen. I guess the timing did a lot.............
And they told me one other thing about GReddy.......
.......I dont know if its true or not but they told me GReddy never physically TESTED the GReddy e-Manage Ultimate on our tCs b4.............
yet they still tell us they will work...........
WTH, can anyone confirm this???
Here's what I got from GReddy website just now:
ESTIMA MCR30/40 1MZ-FE 00.1〜 ○
ACR30/40 2AZ-FE 00.2〜 ○
ALPHARD MNH10/15 1MZ-FE 01.11〜 ○
ANH10/15 2AZ-FE 02.5〜 ○
It has the engine code but not the car.
__________________
__________________
#46
SCI TC 2004-05 TD05H-18G type 31v i/c , sus manifold, racing downpipe(fuel options available, sold separately)
11510090 3,595.00
OPTION #1 TC FUEL MANAGEMENT TC 2004-05 pre-programed emanage, inj. harness, 4x 440cc inj. for use with GReddy tC Racing Turbo Kit #11510090 TC440EMK 795.00
OPTION #2 TC FUEL MANAGEMENT TC 2004-05 preprogramed Ultimate, full harness, 4x 440cc inj. for use with GReddy tC Racing Turbo Kit #11510090 TC440EUK 1,175.00
if they have this, then they have the map for the car from factory,
11510090 3,595.00
#48
I have a harness, but not the one like dezod has to connect everything with no splicing.
to me, it seems like it runs worse than when I had the emanage blue.
my egt reads higher faster, but on a 70mph drive for 2 hours the temp is the same as when my blue was install.
well I boost .25psi higher....WOW haha
are you boosting? if so I hope things go well with yours. and let me know about your fuel set up. injectors and pump. because mine this shop is telling me to redo my whole system....pump line filter rail and injectors.....F that they told me 1000 in parts alone
yeah I saw that soro the map is for 440cc injectors.
this shop is telling me the smart key is fukcing up with the timing or whatever on the greddy, which makes the car not start up...........so the shop tells me
#52
well I did update the firmware but my laptop wont connect to the ultimate so I cant really look at what's in the emanage. the shop did all that stuff on their laptop.
and no i didnt have any acc hooked up with it.
I am in a process of of buying a bigger fuel pump and see if that helps any
#53
ksexton903
06-14-2010 03:54 AM
BlkSandPrlTurbotC
9
06-18-2006 02:17 AM
