greddy turbo help
greddy turbo help
i am currently in the process of purchasing the GReddy Bolt-On Turbo Kit. and it includes:
TD05H-18G turbocharger
SUS turbo manifold
racing downpipe
31V front-mount intercooler
aluminum piping
Airinx air intake (e-Manage & Injectors sold separately)
i was wondering what do i need else to buy to make it complete, and yes i do want the blow off valve sound
and is this a good turbo kit, please indulge me! thanks!
SUS turbo manifold
racing downpipe
aluminum piping
SUS turbo manifold
racing downpipe
aluminum piping
SUS turbo manifold
racing downpipe
aluminum piping
Get a HKS BOV if u love the sound and get a the adaptor flange for aluminum piping... u can get that from HKS SSQV Flange Aluminum - 60mm - PN:1410-SA003
....oh and guages. and a pillar pod.. if u want....hmm... thats about it if u wanna just run 8.5 psi anything more just get a boost controller
I would get an e-manage and injectors as well.
By the way, whats park?
its better 4 the life of ur turbo its either that or wait up to 5mins everytime u drive sumwhere and put ur car in park.
so basically your saying....i should get...
the e-manage; injectors; adapator flange; boost controller; guages; pillar pod; turbo timer (unless i dont mind sitting in the car ; in NEUTRAL; for 5 minutes; and my favorite blow off valve; thats all? sounds like alot please tell me if im missing something to make it more complete
you dont NEED a turbo timer. if you drag race your car from point A to point B , then yes get one. If your gonna be int he boost the entire time your driving, then get one. If you drive it like a normal car and get in the boost every so often for a race, do not get one. its a waste of money. also if you plan on putting an alarm on your car alot of alarms nowadays have turbo timers built in. keep in mind most (if not all) factory turbo cars do not have turbo timers, and why, because it is unnecessary.
Team No Limitz
as far as gauges go, get a wideband 02(such as an AEM UEGO), boost, and either an EGT or Oil Pressure gauge. You will Definitely need larger injectors and engine management...also keep in mind if you have a manual then you might wanna look into upgrading your clutch cause the tq will destroy it over time if you launch hard and beat on it.
yes a clutch is necessary.. though ive had mine on stock clutch and it hasnt slipped yet in over a year.. probably close .. as far as gauges i HIGHLY recommend the zeitronix zt2 with the egt, boost and afr sensor. it is extremely resourceful when data logging and you see what everything is at what rpm. great product.
You don't really need a turbo timer either.
Gauges I'd get a wideband (AEM), boost/VAC, and oil psi.
The rest in the list above is need.
You can also get away without a clutch for awhile.
Team No Limitz
Re: turbo?
Originally Posted by bren2065
if you were installing a turbo would you use a e-manage or a unichip if you dont know how to tune really?
See my Greddy thread (in my sig). I got the info you need.
Get the Injectors & Emanage upgrade, BOV, Flange for the BOV (Aluminum, not steel - you'll need this aluminum welded too), gauges, air/fuel gauge and wideband o2, etc.
I agree with simplyscion. I know the emanage's are popular to get, and for good reason. They work well and when getting the ultimate, there are a lot of "self-tuning" that can be done. I however prefer the Unichip for the exact same reasons he listed. I had it on my supercharger setup on my 03 corolla, and it worked beautiful, especially with the toggling switches for multiple maps. Check em both out, and go with what works best for your setup. You really cannot go wrong.
Hydryman
02-23-2016 03:35 PM
