greddy turbo kit or zpi stage 0 turbo?
Originally Posted by deathbyc4
Neither, Sound performance kit is by far the best setup. Upgradablility is key and they have hit the nail on the head. Just my opinion. I was going to buy the ZPI kit but was drawn away from them for reasons that can be found in the forums. Greddy should have provided a complete kit and seems a little weak on their part to fully provide to the masses. Don't get me wrong, I'm sure both companies mean well, but did not win my satisfaction.
I would say the most upgrade friendly would be Turbonetics because of the larger turbo and proper engine management that can handle timing and fueling control.
If I'm not mistaken, E-manage will handle timing and fueling contorl as well.
No, I was talking about the regular Blue box E-manage. It does timing as well as fuel.
Originally Posted by Stu_Gotti
Thats a whole different game though isnt' it? One is pre-ECU, the other is post-ECU.. that was another big debockle.
True, but they both work.
http://dezod.com/pd_dezod_motorsports_stage.cfm
^ Dezod's S1 Kit is BY FAR the BEST kit to get if you want to do upgrades.
Scroll all the way to the bottom where you can choose your upgrades, you'll be surprised.
this thread is really biased and sided with all the companies, it would be hard for me to decide if i were him because there are sooo many people saying different things about kits.....
Stu_Gotti wrote
"It comes down to end-user opinions really..."
^thats the answer
^thats the answer
^thats the answer
^thats the answer
but my only opinion is that if a company do sell something, they should have it ready. waiting 2 weeks is fine. waiting months for a turbo kit when you paid last year is ridicolous.
i vote greddy kit.
The reason I bought the SP kit was the return fuel line addition. The SAFC is better for me right now because I'm not paying for a piggyback unit like the e-manage if I'm going to buy the AEM EMS when it comes out. And it has less wiring than the e-manage and others, so it's less damage to the harness since the EMS will be plug in and go. So in price you pay more, but you end up with less you have to buy and install in the long run. And I was told 3-4 weeks for the kit since they are now starting to build up an in-house stock of the kit. So, I'll stick with SP.
Why on earth would you do a return fuel line setup on a returnless vehicle?
If you do a return setup you are sending back HOT fuel back into your COOL gas tank and therefore doing damage to your fuel pump overtime. Fuel pumps do NOT like hot fuel, they will seize/burn out overtime.
A returnless fuel system is the BEST way to go especally if you are running a boosted aplication. If I were you, I would upgrade the fuel pump, get a new fuel pressure regulator, bigger injectors and call it a day
I'm not being a total A-Hole, I'm just giving you a heads up and some advice
Well when it comes to boost I would think a return setup would be better because you can change the fuel pressure on the fly. With a return less setup the fuel pressure can not be changed while the engine is in operation because it would not be very reliable. When the boost gets very high (for a return less system) the difference in pressure between the intake manifold and the injector becomes less and therefore less fuel actually gets into the manifold, for any given duration it is open, and therefore you have to make your duty cycles even higher then they really need to be. Now if you increase the pressure of the return less system then at low load and idle it may be hard to control the injectors especially if they are bigger then stock. Now with the returned setup then you can change the fuel pressure based on any real number of variables. Now if you had a dedicated race car then maybe a return less system would be better but with a street car that has to run well in all kinds of loads (low and high) then it is probably a lot better to have the adjustable fuel pressure on the fly. So in reality for small boost either system will work but for any high powered street car then a return system is definitely better. This is how a 500 WHP Evo can be street able.
The return set up is the way to go. Also with the retun less system the stock ecu can still control fuel pressure. When you run boost you want to be able to control the fuel pressure. Every high boost race car or street car I have ever seen runs a return set up... The reason why we can make the SAFC work in this car is part to the return system..
So in essence I still see no gain in doing a return fuel system on a turbo'd tC
Soooooooo........ Can you provide and persuade me with some more information to why I should run RETURN over RETURNLESS?? Because from my past experiences and personal usage I have never ran a return setup
