Guess my WHP
Old 02-17-2010, 08:26 PM
  #41
crush02342002's Avatar
Originally Posted by CarbonXe
440s can't flow enough for 300whp. They'll hit 100% DC before coming close to the 300whp mark. I was on 550cc injectors, with a stock fuel pump, and had plenty of DC left in the injectors, and my fuel pump never showed signs of starvation. I could have run 10:1 @ 13psi all day long and the fuel pump would have kept up.
just a thought real quick...
had a guy run 74% duty cycle @ 10psi (550cc, t3/t4b TT speacial)
after fixing boost leaks= 90% duty cycle @ 10psi after retuning
long story short you can use a mbc to raise boost pressure to desired level but that doesnt mean you get the flow.
In other words i can run stock injectors at prolly 80% dc and push it to 8-10psi with that same turbo if leaks are present. If no leaks then yeah were talking well over 80%.
when i say leaks i mean boost leaks.
think about it this way of how two dissimilar turbos can make the same psi but not the same amount air flow through them.
crush02342002 is offline
Old 02-17-2010, 08:33 PM
  #42
CarbonXe's Avatar
I was in the low 80% DC range for my 550's, 11.5psi at redline, with a 12:1 AFR. No boost leaks whatsoever.
CarbonXe is offline
Old 02-17-2010, 08:38 PM
  #43
ElevationTC's Avatar
Yup but you were also stuck at 43 psi fuel pressure
Remember fuel return setup has couple of plus's!
More volume of fuel.
Equal flow of fuel to all injectors
1:1 rising rate FP , So if base is 50-55 psi then you goto 10 psi its now 60-65 psi of fuel pressure..
Pump gas in your car, squeze pump only half way, then goto 100% same size nozzle and hose..
But much more gas
ElevationTC is offline
Old 02-17-2010, 08:48 PM
  #44
it was just a reply to your example you gave. (10/1 afr @ 13psi)
  #45
anyways jon hows the ride? anything new with it?
Old 02-17-2010, 08:51 PM
  #46
highvoltage1's Avatar
Mike, Awesome sig!!! Chris you really got a way with words! ROFL
highvoltage1 is offline
Old 02-17-2010, 09:05 PM
  #47
^^shut up...lmao
Old 02-17-2010, 09:09 PM
  #48
LOL
Old 02-17-2010, 09:28 PM
  #49
mattTc's Avatar
So 550s should get to 12 psi but with 630s would would be good to have a new fuel pump?
also do any of you guys know of a good boost controller that wont allow to much boost creep? Id love to be able to set psi amount per gear like all the hondata boys lol
mattTc is offline
Old 02-17-2010, 09:38 PM
  #50
CarbonXe's Avatar
Ah, gotcha.
Absolutely love it. Trying my hardest to avoid modifying it. TBE, Accesport and RPF1s possibly coming for the summer though .
CarbonXe is offline
Old 02-18-2010, 01:11 AM
  #51
Ah, gotcha.
lol...hard isnt it?!!! wish ya the best of luck bra. also would like to see some dyno vids or hell even some track vids of it if possible!
Old 02-18-2010, 01:13 AM
  #52
imho both would gain something with the fuel pump but it may not be much.
Old 02-18-2010, 01:27 AM
  #53
cburglb34's Avatar
you will definately be fine with just 630s on stock fuel pump for about 350 whp....the fule pump only atomatizes fuel better...
anyways boost controllers dont cause creep they cause spiking... ive heard the nxs motorsport boost controllers on ebay dont spike and are reliable....but id stick with hallman its gauranteed to be perfect
cburglb34 is offline
Old 02-18-2010, 01:31 PM
  #54
Ronin Scion
Ace83's Avatar
^^ boost controller can cause creep and spiking.. my aem truboost only gave but me some creeping issues no spikes. Ive heard good things bout hallman mbc.
Ace83 is offline
Old 02-18-2010, 01:52 PM
  #55
Music City Scions
rhythmnsmoke's Avatar
Turbo XS mbc will see a small spike on the first initial hit of boost, but settles down and holds pretty good after that.
rhythmnsmoke is offline
Old 02-18-2010, 01:56 PM
  #56
cburglb34's Avatar
i would take creep over spikes anyday...u can tune for creep much easier than spikes as spikes are erratic
Old 02-18-2010, 02:01 PM
  #57
Ronin Scion
Ace83's Avatar
^^ true, thats why im not really worried with trueboost not having an all flat boost level..
but its not all about the controller, proper combination of wg size, dump design, manifold design, turbo size and boost level are important when you are after an all consistent boost
Ace83 is offline
Old 02-18-2010, 02:06 PM
  #58
cburglb34's Avatar
^^ correct again..i believe this third page is full of win! btw travis your setup probably was spiking due to it being a 16g they are known to have a spike, but also for dsms they are known to creep... food for thought
Old 02-18-2010, 02:08 PM
  #59
CarbonXe's Avatar
Flat boost level anyone?
:D
CarbonXe is offline
Old 02-18-2010, 02:20 PM
  #60
Ronin Scion
Ace83's Avatar
decent but theres like fluctuation bouncing from 12 to 14 psi
Ace83 is offline
Quick Reply: Guess my WHP
