Has anyone tried looking into this....
Team No Limitz
I know the old supra and 3sg MR2 guys used to use the techtom chips for the factory ECU, but that was mainly obd I. I wonder if they would be willing to make a solder chip for our ECU's and hack into the factory tune
www.technosquareinc.com
Team No Limitz
Originally Posted by HP_Pirate
your better off going piggy back or reflash IMO.
You can do a lot more with a piggy back and get better results if properly tuned.
^Hey simply, idk if you've talked to Charles about it and I know you've got the Unichip but he's got his ultimates set up so that the ecu will never relearn. He told me he's never reset his ecu once while he's had it. I agreee though a reflash is a much better option most of the time.
Problem is no Toyota ecu has been hacked (except that obd I) and well I don't think there ever will be. I think we either need to stick with the piggybacks are start looking into stand alones (probably a Megasquirt or AEM).
Originally Posted by OuterHeaven
Problem is no Toyota ecu has been hacked (except that obd I) and well I don't think their ever will be. I think we either need to stick with the piggybacks are start looking into stand alones (probably a Megasquirt or AEM).
Team No Limitz
no, I think you guys are misunderstanding...this company doesnt do reflashes...they are solderable chips such as APR chips for VW/Audis, Hondata chips etc
Team No Limitz
Team No Limitz
Actually it could be like Uberdata (http://uberdata.pgmfi.org/) and the Honda community. Buy like 60$ in parts and you can reprogram your own ecu and burn your own chips. I just don't know if many people on here are willing to do this kind of stuff on their own ecu's.
Also in the Mitsubishi (Evo) community they have the ability to reflash their ECU through the OBD-II port. This would be something I would be highly interested in.
in all reality anything is possible. it is a matter of how far you are willing to screw up your ecu,and how much money you want to pay. a piggy back is the cheapest and easiest for companies to produce at low cost. and one of the most profitable( most likely)
A friend of mine is an electrical engineer and also has a degree in programming. He has a WRX and he did did some crazy ____ to his stock ECU. he tried to explain it to me once but it was way over my head had somthing to do with algorythms i think. not sure. anyways he said best bet is to literally reprogram the ECU as in write a new program for it or modify the program. OR do a standalone. the soldered in chip he said is also a good idea but you have to be concerned with over heating the ECU because of bad programming or instalation of the chip
CSOCSO
Scion tC 1G Aero & Exterior
27
05-13-2009 03:46 AM
IIPTC
05-07-2009 10:52 PM
