heat shield
Old 09-30-2008 | 06:02 AM
preston2580's Avatar
Default heat shield
i need a heat shield or should i just get a racing radiator but the turbo is starting to warp the plastic on it so i need to fix that asap, any ideas on where i can get a heat shield, i have the dezod s1 kit
Old 09-30-2008 | 06:03 AM
aen's Avatar
aen
can we see pictures?
Old 09-30-2008 | 09:15 PM
Jacque766's Avatar
Someone had a pretty cool idea of taking a Stainless pot cutting the top off, cutting out the shape, and then drilling mounting holes for it and it came out really nice after polishing it up a bit. But depending on the angle of your turbo it may not work for you to keep it from warping the rad.
The best thing I have seen as far as function is the insulation wrap.
Old 09-30-2008 | 10:24 PM
JL56TC's Avatar
pix please
Old 09-30-2008 | 10:55 PM
yellowxhoodie's Avatar
just cut the plastic off of it like the guy who buy the mishimoto do. youll be fine
Old 09-30-2008 | 10:59 PM
Ace83's Avatar
Ronin Scion
did you mean the plastic shroud of the rad fans? you can even do both, mish rad and cut part of the plastic or heat shield may a turbo blanket too
Old 10-01-2008 | 05:03 AM
k thanks, can i jus cut the plastic off?, im working till 430pm tomorrow so ill take pics when i get off work
Old 10-01-2008 | 09:36 AM
ChicagosFinest's Avatar
OhioScions
grab a turbo blanket. Best solution IMO
Old 05-07-2009 | 01:42 AM
Ace83's Avatar
Ronin Scion
summer is up and its time to get more cooling..
anyone have experience on using this kind of turbo blanket? any turbo blankets you can recommend? I have heard some turbo blankets that are smoking under the hood, i just dont want to buy the wrong one
http://cgi.ebay.com/ebaymotors/T3-T4...ht_3486wt_1192
Old 05-07-2009 | 01:52 AM
crush02342002's Avatar
give a shout to TheFantasticG...hes got a pretty good one...the only thing i dont like about it is its black and it faded a little but you can run that car at the track all day long and put your hand on the blanket after a run...its warm but not hot...I was very impressed with it...
btw im right now in the middle of making a turbo shield....stainless steel....I maybe doing more fab work as things progress...
Old 05-07-2009 | 02:07 AM
Ace83's Avatar
Ronin Scion
yeah i've seen his thread, it looks kinda big for my setup.. and im looking for something silver than black.. i have a garrett heatshield that needs to be modified to fit.. im also looking for some heat insulation for my ac lines.. maybe something like these might work
http://www.jscspeed.com/universal/thermotec/sleeves.htm
http://www.jscspeed.com/universal/th...at_barrier.htm
or maybe this might fit better
http://www.jscspeed.com/universal/thermotec/turbo.htm
Old 05-07-2009 | 02:15 AM
prolly work
Old 05-07-2009 | 04:32 AM
thendawg's Avatar
OMG i had been looking for that everywhere (thermo sleeves) :D Thanks for the link Ace!
Old 05-07-2009 | 04:37 AM
Ace83's Avatar
Ronin Scion
haha i can go search go stuff all day i just want to hear people who have used it and see how it works.. i've spent so much money try stuff and looking for stuff to work, and well i dont have extra right now to waste lol
Old 05-07-2009 | 04:50 AM
Skeeeett's Avatar
kk wel i used this one that ace83 posted up...works great and def keeps the engine temps down by a lottttt
heress a pic..i have more but all look the same...its really easy to do with the kit above
and i also used that silver heat adhesive stuff to go over my radiator and its been good ever since ...also heat wrappted my downpipe loll
Old 05-07-2009 | 04:54 AM
Ace83's Avatar
Ronin Scion
what material is inside that wrap? it like easy to work with in tight spaces like its flexible?
Old 05-07-2009 | 04:56 AM
Skeeeett's Avatar
the material inside the wrap is just regular heat wrap material like that fiberglass kinda stuff haha ...then u wire them together and then wrap it round and tie the wires together haha...the pic is kinda bad...it actually is more rounded and shapped to the housing than the pic looks..
Old 05-07-2009 | 04:59 AM
Ace83's Avatar
Ronin Scion
no smoking issues or anything?lol its coz with my setup its tight to work with since its not a top mount like you have
Old 05-07-2009 | 05:04 AM
Skeeeett's Avatar
well u see how i have my heat wrapped downpipe...that material is inside the silver/chrome wrapped around the housing...soo wen that gets wet...if yours ever does it will just smoke to just get off the water and burn it off...i have vents in my hood right ontop of the turbo so it smokes wen ever it gets wet...and most likely wen you first put it on it will prorobly smoke to burn off some chemicals and oils at first but its normal for it to smoke at first
Old 05-07-2009 | 11:55 AM
yeah the dei (i think its dei..lol) header wrap will smoke at first but then it will level off untill you either get it wet or oil on it...
