help with Fuel return system
Old 12-16-2011 | 08:21 AM
kimbym05's Avatar
Angry help with Fuel return system
Im looking to get a fuel return system for my boosted tc,i know ptuning has one and dezod has one as well.anyone know which is better? Or if there a better one out there?or better solution like custom making a kit.
Old 12-16-2011 | 12:38 PM
BOOSTit06's Avatar
I have the Dezod fuel return system, A friend of mine has the Ptuning fuel return system. They both work flawlessly. Either one would be a good choice.
Old 12-16-2011 | 02:07 PM
paul_dezod's Avatar
Scionetics
KAD
We're offering 5% off of any online purchase over $100 through the end of the month. Food for thought.
http://www.dezod.com/pd-return-fuel-system-tc-05-10.cfm
Old 12-16-2011 | 02:22 PM
PeArLwHiTe07tC's Avatar
speaking of fuel return paul, does it come with a new sending unit or do u have to drill out the existing?
Old 12-16-2011 | 02:40 PM
BOOSTit06's Avatar
^^^you have to drill out your own bud. There is a pretty good DIY one here somewhere...I havent seen it for years though lol. Im sure if you talk to Paul he can get you on the right track
Old 12-16-2011 | 02:49 PM
yeah thats kinda what i figured. i found the diy on dezods site. the way it makes it seems, as if it comes with the sender too. no biggie, ill just buy another one.
Old 12-16-2011 | 02:51 PM
paul_dezod's Avatar
Scionetics
KAD
Older editions came with the sending unit. Newer ones don't because cost on them sky-rocketed...
Old 12-16-2011 | 05:37 PM
kimbym05's Avatar
I already have the walbro fuel pump i think i saw on your site that its like 70 dollars cheaper without it correct?
Old 12-16-2011 | 05:40 PM
kimbym05's Avatar
How much boost are you running with the kit boostit06?
Old 12-16-2011 | 05:48 PM
paul_dezod's Avatar
Scionetics
KAD
There is discount for removing the pump from the setup.
Old 12-16-2011 | 06:27 PM
BOOSTit06's Avatar
Im running 21 psi
Old 12-16-2011 | 07:49 PM
kimbym05's Avatar
Sweet im guessing ur built..im on stock motor oí wanna try and boost 11psi
Old 12-17-2011 | 01:08 AM
BOOSTit06's Avatar
Yep built motor. The fuel return system will really allow you to expand.
Old 12-17-2011 | 03:41 AM
crush02342002's Avatar
WORD!!!
consider this, on 550cc injectors and stock fuel system I maxed out the injectors at 12psi (iv done 14psi on stock fuel system however leaks screwed up airflow), now on the same exact turbo system along with a dezod return fuel system (using dw 300lph fuel pump) im able to boost 23psi on 550cc injectors @93psi peak fuel pressure.
upping fuel pressure is key to get the most from your injectors
Old 12-17-2011 | 04:26 PM
kimbym05's Avatar
Damn sick...i deff need one . plus im running ethanol so i need it even more lol.....i want one!!!!
Flyfishfreak
06-10-2016 03:55 AM
carid
03-30-2015 08:08 AM
spawnconnery
12-18-2014 09:38 PM
eric_m
79
03-17-2013 01:21 AM
DjFrOsT
14
12-23-2003 02:58 AM
