help is needed.
help is needed.
i find a guy sellin his turbo kit and he wanted about a little over 1k for it. it comes with everything. i was woundering if its a good buy or not and im not sure if some of the part are knock off or not so any help would b great. thanks.. here are the part...
-42 Trim T3/T4 Garret Turbo
-Megan Racing Top Mount Manifold
-Injen Custom Intercooler Piping
-550cc Injectors
-Mishumoto Front Mount Intercooler
-Injen Air Filter
-Turbo XS Blow Off Valve
-Tial Wastegate 38mm *8psi spring* (also comes with 11psi spring)
-Turbo XS Manual Boost Controller
-One6 Motorsports Oil Return and Feed Lines (with correct Fittings)
-Modded Oil Pan
-AEM FIC (tuned at 8psi))
-Plug and Play Boomslang Harness
-AEM Wideband -Autometer Boost Gauge
-Custom Molded Gauge Pod
-Samco Couplers and Clamps
-Custom Downpipe & Wastegate Dump
-High Temp Silicone Hoses and T fittings for Vacuum Lines
-Hayden Trans Cooler
-Apexi Turbo Timer
-All fittings and flange gaskets
-550cc Injectors
-Injen Air Filter
-Modded Oil Pan
-Apexi Turbo Timer
if it has name brand parts than no, u said aem fic, tial WG, turboxs bov, megan mani ETC. doesnt sound ebay but def a custom cheaper kit. but if its legit brand parts than it should be good to go, just watch out for the megan mani its prone to cracking
i saw it on ebay but its not a ebay turbo kit. im guessin he put together the turbo kit himself...
and if i did buy the kit, how much am i lookin at if i would get a 50 trim turbo. and do i need anything else to get it goin? also it came off of a 05 tc and i got a 08. i wanna see how much im gonna end up spending cuz if its more then what it worth the is it better off gettin a new turbo frm dezod, ptuning or etc. thanks
SJMiller
09-12-2015 06:33 PM
