help please: turbo troubleshooting
Old 07-26-2010, 04:27 PM
x_Batman_x's Avatar
Default help please: turbo troubleshooting
hey guys, for the past two weeks my tuner and I have been working to rid my car of the P0171 (system too lean) code. The car is not running too lean in anyway as indicated my my wideband, and the tune feels crisp and smooth. I am very happy with how the car feels and its power output (250whp) but this darn light is quite annoying. Has anyone experienced this problem that might be able to lend me some advice?
Its a Dezod S1 kit with 850cc injectors and an AEM fi/c.
Last edited by x_Batman_x; 08-05-2010 at 04:26 PM. Reason: changed title from P0171 to turbo trouble shooting; topic has extended to different areas
x_Batman_x is offline
Old 07-26-2010, 05:34 PM
bdyer666's Avatar
I ran into it with my setup apr inline, 850s, 60-1, custom turbo kit. What I needed was to adjust the injector adjust alot more to get the fuel trims as close to 0 to -5 range as possible in all loads and rpms. Once i had the trims dialed in the code stopped appearing. so it is probably your fuel trims in some spots that are a lil off throwin it. At least that is what it was for me. Hope that helps.
bdyer666 is offline
Old 07-26-2010, 05:35 PM
bdyer666's Avatar
If that doesnt help ask paul he is a freakin genius.
bdyer666 is offline
Old 07-26-2010, 06:08 PM
x_Batman_x's Avatar
hmm ill talk to my tuner about that. Right now my STFTs run between 0 and ~+5. Ill see if favoring the negative side helps. Ill probalby call Paul today after work too....
Old 07-26-2010, 08:21 PM
Scionetics
KAD
paul_dezod's Avatar
Emailed ya back!
paul_dezod is offline
Scionetics
KAD
paul_dezod's Avatar
Brandon, how is she running?
Old 07-26-2010, 10:05 PM
Team Scionara
skinnayyy's Avatar
i get system too rich every time i start my car. Dan thinks he figured out how to get my idle working right, because thats where it's from. I don't know if he tested out his method on yours though. all my fuel trims are always at 0 +- 3 except at idle it's -22.
skinnayyy is offline
Old 07-27-2010, 12:51 AM
x_Batman_x's Avatar
yeah after talking with Paul over email and examining my fuel trims i think i know what the problem is. My LTFTs are like 20 at idle and 44 while driving. My whole fuel map needs to be shifted so that the the STFTs counteract the LTFTs and eventually they will both zero out. I tried calling and texting dan earlier but he hasnt responded. I actually thing the best thing to do would be to reset the ECU to erase the LTFTs and then redo the whole fuel map, that way the LTFTs and STFTs wold both be close to zero...
thanks again paul for your help!
Old 07-27-2010, 01:17 AM
Ronin Scion
Ace83's Avatar
^^ yes do that
Ace83 is offline
Old 07-27-2010, 06:47 PM
x_Batman_x's Avatar
confirmed plans with tuner to retune fuel map according to above.
Will update later this week :-)
Old 07-27-2010, 06:51 PM
DezodDon's Avatar
I do believe I spoke to your tuner today, that is what I told him to do. Hope it works out.
DezodDon is offline
Old 07-27-2010, 08:59 PM
bdyer666's Avatar
Paul you def helped out alot im changin plugs today to two steps colder and she is doin good i still keep findin random spots that i need to smooth out in inj adj but its cause im purposely lookin for them. But still with as much time as i have fugin with it i would love to see what you can do in a day of tunin.
bdyer666 is offline
Old 07-28-2010, 08:43 PM
x_Batman_x's Avatar
thanks Don. You probably did, he was saying he was going to call. Cant wait to get this fixed :-)
Old 07-28-2010, 10:31 PM
gwopsta's Avatar
i love ur sig
gwopsta is offline
Old 07-29-2010, 11:54 AM
bdyer666's Avatar
^its all thanks to you
bdyer666 is offline
Old 07-29-2010, 07:42 PM
Scionetics
KAD
paul_dezod's Avatar
So, if you need some help or a nudge in the right direction again, send me a log.
Scionetics
KAD
paul_dezod's Avatar
Glad to hear! Just get that O2 map coinciding with the fuel map working out right and you will be golden.
Old 07-30-2010, 02:38 PM
SilverCFtC's Avatar
Damn I'm gonna be the only non-turbo tC left in Michigan Congrats on the upgrade man!
SilverCFtC is offline
Old 07-31-2010, 11:43 PM
elcapetan's Avatar
system too lean codes only apply to partial throttle. the ECU takes over under WOT. so go over your partial throttle tune.
elcapetan is offline
Old 08-02-2010, 02:07 AM
x_Batman_x's Avatar
Car is running real smooth, definitely happy with the feel and pull.
One more question though... Does anyone know if the ECU's open loop fuel map changes at all after diagnostics have been completed? I'm pretty sure that when my tuner finished up on thursday the AFRs ran around like 11.7 under boost at WOT... strangely enough though now that all the run cycles have been completed (as indicated by the SGII reading -READY-) my AFR under boost at WOT is now pegged right at 10.6... Not really concerned since thats not rich enough to cause any problems but loosing that bit of power is kind of annoying lol. Anyone have any idea as to why I'm getting this shift? Nothing else seems to have changed (idle, partial throttle boost etc...)
Quick Reply: help please: turbo troubleshooting
