HKS BOV
HKS BOV
I am getting a used stage 0 with in a week. It does not come with a bov. My friend has a gli and he just took off his hks bov and said he would give it to me. I know i need a flange to get welded into the pipe, but on his bov it seems different. I don't know how it is going to stay in the flange. He took off everything that came with the bov. Am i going to have to get the bov welded on also?
well, the flange allows you to use a snap ring to connect the hks bov on the intake pipe.....i don't think you want to weld the bov on, in case you need to take it off, etc.....any pics, etc would also help!!
Originally Posted by mahalzkita28
yea, you will need snap ring pliers to take the bov off the flange. you can pick up a set at sears for like 15 bucks. without the pliers it will be damn near impossible to take it off.
i need to the the bov on not off
the flange is on the intake pipe, to the throtte body.....and the bov is separate.....you need to use a "snap ring" to secure the bov after you have seated it on the flange....in order to do this, you'll need some snap ring pliers (look like pliers with 2 teeth on the ends)....without the snap ring and snap ring pliers, you won't be able to put on the bov....unless there is another way thats not as pretty but gets the job done.....get 2 coupler clamps, and use that to wrap around the flange and bov and tighten as much as you can, that worked for me when i couldn't get the snap ring in! lol
sry i was just bein retarted
malibuboy did u like your stage 0?
how long did the install take?
before someone goes off on me that i didn't even know how to put a bov in let alone a turbo my 3 friend are helpin me install the kit.
they know a lot more than i do.
i don't have gauges yet but i am looking for them now. Also i have to change the spring in the wg form an 8psi spring to a 6psi spring. I don't want to take any chances. But damn 260 on a stage 0 thats great. i was aming for about 220 at first. did u have a stock clutch?
SloTC1
08-16-2018 03:45 PM
Hydryman
02-23-2016 04:35 PM
