HKS TURBO TIMER..DIY PLZ?
its the blue and red wire under the steering wheel i believe...there is a diy on here already................SEARCH......................
https://www.scionlife.com/forums/vie...dy+turbo+timer
hey so heres a question...i have the apexi turbo timer. and i cant figure out how to get it past the 1 minute setting. the online instructions on their website are hard for me to understand...do i even need it past 1 minute?
no ptguy.....our oil temp is weird......i have mine set at 40 seconds now.......if the oil is above 200 degrees ill do 50 seconds....our oil takes so long to cool and it has a high operating temp
Originally Posted by Mrsanchez925
So is it easy to install once u get the Ptuning wiring harness??
is it all PLUG N PLAY
or do u still have to do some wire splicing and connecting?
The HKS Turbo Timer Type-1 offers all the features of the Type-0, PLUS several monitoring and measurement tools. Vehicle speed and RPM can be displayed on the Type-1's LCD monitor and a speed warning level can be set. A 2 stage RPM warning can also be set and used as a shift light. When a warning level is reached the Type-1's LCD monitor will switch from blue to red and an audible beep will sound.
The HKS Turbo Timer Type-0 is a basic turbo timer that features an auto mode that adjusts engine idle time according to the most recent driving pattern, multiple preset times, audible alarms and a volt meter. The easy to read back-lit digital LCD display flashes between orange and red during the countdown The Type-0 is ultra compact, less then a 1/4 din in size and available in a black or silver case.
Type 0 = Orange/Red
Type 1 = Blue/Red + Audible beep
http://www.hksusa.com/content/pdf3561.pdf
Hydryman
02-23-2016 03:35 PM
