Hot side gasket
you can buy a gasket if you like or try other means. if the mani gasket seals then yes..if it doesnt then get a new one...sometimes they can be reused but sometimes they dont quit work out. so if you got the extra change in your pocket to get one then do so
+1, trial and error. A new gasket is what, $30? I reused the old one, however it started leaking after a short while. Took maybe 45 mins to replace.
If the OEM manifold gasket is in good shape then you're probably safe to use it. As for a gasket between DP and Turbo, I opted to use one even though the Turbonetics kit doesn't include one and most kits don't. High temp RTV is your friend as far as leak prevention. Small leaks here and there will cause your AFR readings to be chaotic and give you a headache while tuning.
U don't necesrily need one. If it doesn't leak, ur golden. If it does unbolt the down pipe and use a ruler and put it flat against the flange and use a flash light from the other side of the ruler to veryfy that the flange is not warped or something. Mine was and RTV didn't fix the problem. Only thing that did for a while was to use high temp bearing grease in between (old tuner trick), but it started leaking again after a couple of months.
Just sand it donw with a block to make sure is good to go, same with turbo hotside. Once done coat both surfaces with bearing grease and it will seal it up great. Take it from somebody who worked on that thing like 5 time to get it right :-(
As it is important to seal any leaks on the compressor side of the turbo it is just as important to seal any leaks on the turbine side of the equation.
A leaking manifold gasket can cause an increase in spool and incorrect AF readings
A leaking turbo inlet gasket can cause the same problems listed above
A leaking turbine to downpipe, with gasket or not, will cause incorrect AF (lean) readings. This is important when tuning with a piggy back as sealing all that up makes for a quicker more accurate tune and keeps CELs for too lean and too rich off (assuming your tune is correct)
This is important.
Plus they are only $10, ya cheap skates!
http://www.dezod.com/pd-dezod-motors...ine-gasket.cfm
They are included with our turbo kits.
iv heard that too don from another local tuner shop..iv never done it but iv seen it work. I too beleave in using a gasket for everything if possible but somtimes we get a little too froggy and dont want to wait.
And to add to what you said about leaks, you are correct. The AFR's will read higher than normal, with the small leak I had it was about .5 AFR difference.
PTUNING
12-11-2014 08:09 PM
PTUNING
12-06-2014 03:58 PM
