how bad is the lag?
how bad is the lag?
my buddy currently has the trd supercharger, he loves it but wants more power. so he wants to go turbo, he just feels that the lag will be horrible compared to the sc. he wants like the dezod kit, or the TT kit.
Re: how bad is the lag?
I have a .48 a/r 60 trim, and it spools full boost around 2600 RPM's
I believe most people on here run a T3/T4 .63 a/r, and have quick spools also
i havea 50trim 50ar and i spool @ 3500 fully
Turbo is worth it though because we get full boost @ 3500 where S/C you dont get it till higher in the RPM range. You learn to drive to eliminate lag, let it wind out a little more and it just GOES
gt3076r here and lag is negligible, i even hit full boost 6-7 psi at part throttle where I only expect to boost at 3 psi.. lag exist but as the turbo starts spooling, it hit full boost fast.. and yeah there are several ways to manage lag
What boost if your buddy running? If he is running 7 lbs tell him to go up to 9.5 since he already has the charger. All he will need is the NST pulley and a new belt (which they tell you the size he needs). Other then that ...thats it. Or he can buy an ECU (which he will need for a turbo anyway) and get a custom 10.5-12lb pulley from NST and run that for a while. If he still wants to go turbo after that he will already have the ECU and just spent the xtra money on the pulley and new belt.
If you take the time to to design a kit with a turbo that suits your needs...
The turbo will spool just as fast as the S/C and kill it in the midrange and high end.
You get way more for your money from a Turbo than an S/C(for the Scions)
S/C(for the Scions) are made for a purpose.............that little extra hp that the dealers can offer for allot of $$$$ (when you look at return on investment)
Regards-
Todd
Regards-
Todd
well we priced it with all the goodies that icenine has to make 300, such as ecu, injectors,pulley,intake, header,etc would be about $3200. could spend like 300 more and get the TT kit
steeze69
05-24-2021 02:57 AM
BlingSlade
10-19-2016 12:39 AM
