how long will a stock clutch for the tC hold with 12psi?
Old 03-06-2009 | 06:22 AM
turbo_tC4's Avatar
Default how long will a stock clutch for the tC hold with 12psi?
i'm wondering how much the stock clutch on the tC will hold if boosting 12lbs. I'm not a crazy driver like some people. No hard launches or anything. And im not like those people who race and go crazy everyday. Again, my question is. How long would the stock clutch for the tc hold if boosting 12 lbs. thanks.
Old 03-06-2009 | 06:30 AM
rozz-tC's Avatar
Didnt you already make a thread about this? buy a damn clutch, jeeze.
Old 03-06-2009 | 06:31 AM
equinox2355's Avatar
well at 12 lbs, the stock clutch will wear out a lot faster. I would say anywhere from 1 month to 3 months, depending on how you drive, and the horsepower transmitted to the tranny.
Old 03-06-2009 | 07:16 AM
aen's Avatar
aen
not long mine slipped at 5 pounds!
Old 03-06-2009 | 07:19 AM
Mouse's Avatar
well here is my 2 cents... I have heard numerous times that the stock clutch will handle up to about240hp....but if your plans are to go at least that if not higher... your best bet is to replace the stock clutch before it fails...and while you are at it (installing a new heavy duty clutch)....it would behove you to install a LSD at the same time if you're looking for those kinds of HP numbers
Old 03-06-2009 | 07:36 AM
unxpectederror's Avatar
the stock clutch can handle around 200-220whp, you will blow up your clutch the first day
Old 03-06-2009 | 11:26 AM
crush02342002's Avatar
this is coming from experiance, the stock clutch doesnt like 12psi at all........it will kinda hold at first but heats up real effing quick and slips real bad. it happens to me all the damn time. 7-8psi it holds the power a little better but will eventually heat up and start slipping. iv been working on trying to get a stage 4 clutch but of course plans didnt really happen.
Old 03-06-2009 | 02:26 PM
rhythmnsmoke's Avatar
Music City Scions
All solely depends on how you drive it. I can make it wear out in a matter of hours, or a matter of months.
Old 03-06-2009 | 02:51 PM
Ace83's Avatar
Ronin Scion
its mainly more on hp/tq than boost.. it wont last long if you race or drive where quick engagement is necessary.. you can make it last a bit longer when you take it easy while shifting even you boost.. still better to get a clutch at hand though until the day comes that your clutch goes
Old 03-06-2009 | 03:22 PM
Crayola_G's Avatar
itll prob hold a couple months depending how you drive itll def slip on you a couple of times before it goes.
Old 03-06-2009 | 03:24 PM
yellowxhoodie's Avatar
it will last exactly 7.2436 launches.
its really impossible to tell.
this is the equivalent of the "how long will my stock shocks last w/ springs" threads
Old 03-06-2009 | 03:25 PM
Music City Scions
I got a Brand new TRD clutch for sale if you are interested.
Old 03-07-2009 | 05:58 PM
BlackKnight's Avatar
Music City Scions
X2.
Old 03-07-2009 | 06:38 PM
Pecka13's Avatar
well at 9.5 lbs of boost mine handled about 2 months. And then i found myself slipping all the damn time still driving it though its been like 5 months now. Its still driveable, but if you wanna race, your not going anywhere
Old 03-08-2009 | 07:18 PM
foretwoone's Avatar
Well since we're on the topic and my parts will be in very shortly, what do you guys find to be a nice, smooth engaging clutch that can hold atleast 315/320ish? Not going puck because im not going any higher in the future.
Old 03-08-2009 | 07:20 PM
famous last words
Old 03-08-2009 | 07:23 PM
jwaggz82's Avatar
Originally Posted by Ace83
its mainly more on tq than boost..
Your torque #'s are what you need to worry about. At 12lbs nomatter how you drive you will be blowing your clutch within a 6month span for sure nomatter what. When you shift you are causing A LOT more friction due to the torque levels. Don't wait till you blow your clutch. I put a new clutch in, flywheeel, and LSD in at the same time. I did all of that while I was running 9.5lbs - my clutch feels great, grabs low, and I didn't have to worry about blowing my clutch and not being able to get to work.
Old 03-08-2009 | 07:24 PM
aen's Avatar
aen
get a puck, it's the only way to be safe. and get power
Old 03-08-2009 | 07:26 PM
scikotictc232's Avatar
what clutch does everyone recommend for 300 - 350 ?
Old 03-08-2009 | 07:27 PM
foretwoone's Avatar
I know a puck will hold, my fear is driveability. Does it allow any slip for times in traffic? Seems like most people on here were running standard disc clutchs rated for 350 and up tq.
