how much boost should i go for?
Old 03-05-2009, 03:52 AM
turbo_tC4's Avatar
Default how much boost should i go for?
i'm about to get my tC tuned by CFT (central florida turbo) this weekend. And still deciding on how much i should boost with STOCK clutch. Right now i have the following installed..
Turbonetics turbo kit (complete kit)
AEM F/IC
K1 connecting rods
Cometic Head Gasket
Wisco low comp. Pistons 89mm Bore
And a custom axle back exhaust
I am wondering how much i can boost with STOCK clutch.
turbo_tC4 is offline
Old 03-05-2009, 03:54 AM
rozz-tC's Avatar
Alot of it depends on your driving style, but i wouldnt go too much over 7-8psi untill you get in an aftermarket clutch. Even that will be hard on it if you beat on the car.
the higher you go, to quicker its gonna get shredded.
rozz-tC is offline
Windu's Avatar
crank it up!
Windu is offline
Old 03-05-2009, 04:06 AM
jct
jct's Avatar
crank it up right before it blows
jct is offline
Old 03-05-2009, 04:17 AM
athletefeet66's Avatar
get it tuned on like 10-12psi but turn it down and just run wg pressure until you get an aftermarket clutch. unless you can wait to get it tuned...
thats what i would do...
athletefeet66 is offline
Old 03-05-2009, 04:19 AM
On3Sh0tBlaz3's Avatar
thats on you bro, im running on 8lbs of boost till my clutch, flywheel, clutch line, and motor mounts go in. at that point i MOST LIKELY will be cranking it up to 10psi to reach my goal hopefully
On3Sh0tBlaz3 is offline
Old 03-05-2009, 04:20 AM
dave2610's Avatar
im running 10 lbs on the stock clutch but i dont drive like an a hole
dave2610 is offline
Old 03-05-2009, 04:23 AM
turbo_tC4's Avatar
but do you sometimes boost once in a while? And how long do you think the stock clutch will last with 10lbs?
Old 03-05-2009, 04:31 AM
dave2610's Avatar
yes i boost once in a while. we will find out how long it will last. 4k miles so far
dave2610 is offline
Old 03-05-2009, 04:32 AM
turbo_tC4's Avatar
how much whp and wtq were you running?
Old 03-05-2009, 04:36 AM
dave2610's Avatar
270 whp 240 wtq
dave2610 is offline
Old 03-05-2009, 04:39 AM
turbo_tC4's Avatar
270 whp 240 wtq
at 10lbs? i was expecting more than that.. maybe in the 300+whp &w wtq range..
Old 03-05-2009, 04:42 AM
numbers depend on many different things, cant just expect everyone at a certain boost level to have a guaranteed hp/tq range
Old 03-05-2009, 04:44 AM
dave2610's Avatar
270 whp 240 wtq
ran into a fuel issue injectors maxed out before they should have still room to grow
dave2610 is offline
Old 03-05-2009, 05:02 AM
tCtCtC's Avatar
go 20 psi. we need a good blown motor story
tCtCtC is offline
Old 03-05-2009, 05:15 AM
firesquare's Avatar
you should just go buy a clutch, injectors, and fuel pump. insure yourself reliable daily boosted fun witness no worries on things wearing out and such. boost safely!
with your setup i say 8-10 will be ok but get a clutch that will handle the torque.
firesquare is offline
Old 03-05-2009, 01:18 PM
m6ar2cel6oTC's Avatar
boost till you get to 300whp or 300 torque! thats when my clutch went. but then again i used to beat on my car like crazy lol might as well boost high so when you clutch goes your already tuned for high boost. and dont have to get retuned.
m6ar2cel6oTC is offline
Old 03-05-2009, 01:32 PM
CarbonXe's Avatar
I raped my clutch when I was putting 295 down. Any boosting in 5th gear and the clutch would just slip. I dropped the boost down to 6PSI (230-250WHP) and the clutch has been fine.
CarbonXe is offline
Old 03-05-2009, 02:56 PM
turbo_tC4's Avatar
what exactally do you mean by the clutch would just slip. How long do you think it'll last at about 9lbs? i mean, it wont wear out right away..
Old 03-05-2009, 03:10 PM
CarbonXe's Avatar
If I kept driving around at 295WHP, I think the clutch would have lasted about 2,000 miles.
CarbonXe is offline
Quick Reply: how much boost should i go for?
