How much hp?.... TRD S/C etc..
You'll see a noticeable increase in power, feel, and look of your car. I don't have exact numbers.
After you put in the supercharger and follow the list I posted, you'll probably be running 200-210 at the wheels.
And if you're in Texas, do not get the stainless steel **** from TWM. You'll brand a TWM logo into your palm.
i dont understand why people are suggesting that he upgrades the clutch and the flywheel. This is an automatic, there is no clutch or flywheel.
Upgrade your torque converter if you want a fast drag car.
Originally Posted by zucc
i just want 2 b faster my auto is slow as f*** and i need speed and i have 6000 2 do it with lol. w/o voiding warrenty
Anything can CAN void your warranty.
Besides the engine, you should get a pair of stickier tires, sway bars, and a lowering kit.
thats about all you can do if you want to make sure none of your warrantys are voided.
I feel the need to step in and remind all of us (perhaps to some this will be new and surprising) that adding after market parts or modifications doesn't Void your warranty. This only happens if it is determined that the part or modification caused a problem that the dealer is investigating/servicing. This is a law to protect us consumers from the dealer refusing to cover repairs under warranty on say, your transmission, because you added some aftermarket headlights that burned a wire.
So, in that case... consider a quality turbo kit and other high-quality parts even if they modify warrantied parts because chances are if you install them right and take care of your car you won't have a warranty issue in the forseeable future.
^^ no, it doesnt "void" the warranty. You just have to make sure the dealer doesnt try to refuse service by blaming a part you installed. Usually this should be pretty easy to do since the burden of proof lies on them. But, in the case of the spun bearing I mentioned they kind of bullied the guy into paying for now by giving him a "discount" they would pull back if he lost the fight... I still think he should be able to get his money back if he continues to fight it though. They key though in modifying your car is to always do your research and know how it all works so you dont do anything that will damage your car, and will know if the dealer is trying to pull something over on you.
NEVER trust the vendor or manufacturer of parts 100% to tell you of any ill effects or even the true numbers. If you are going to mod, it is worth the time to learn how the system works. That knowledge will help you make more sound decisions and catch any misinformation that you may recieve if there are issues.
Originally Posted by mattvs
I recommend the stainless steel piping and high flow cat with resonater. This will run you $750. It will look good, sound good, and flow well.
Save yourself $450 and get the megan catback exhaust.
rain7905643
06-13-2018 05:29 AM
airmankevin1
11-17-2015 05:44 AM
