HOW MUCH TIMING
HOW MUCH TIMING
im running 9.5 s/c with emanage ult and meth kit, how much timing are you guys pulling and or are you able to pull timing with emanage ult, the reason im asking i was looking at my tune map , but no signs of any timing map almost as if my tunner didn't use a timing map. does anyone know if you need to pull timing , my understanding cooler temp means you sould be able to tune safer and adjust timing for more power.....
um you don't get power by pulling timing. from what i know you do it to keep your engine safe from knock. knock is most prevalent in the summer time when temps are hotter out... also you posted in the wrong section thus why your getting no responses
yes it has a trd flash, and emanage ult .the first time i took my tc in for a tune they had problems with timing , tuner asked if my harness was installed correctly, and yes dezod plugnplay . so i thing all they did was play with a/f. no timing. so you are saying a conflict between trd flash and emanage? should get a oem ecu with no flash?
he did but he said not to worry about it ,but i had a feeling about it , but since a was already there i just got it tuned, if i install a oem ecu with out trd flash get it tuned do you think ill gain some power and maybe better gas milage,i was getting about 327 miles with a full tank before i installed emange and meth kit. now im getting 200-230 if that
Well it does smell like it's running rich. And my foot always been heavy even before tune
how much timing
im saveing money for a tune soon, with a oem ecm. but i hope my tuner gives me a fair price for full new tune. its so expensive getting a full new tune from scratch......
