Hydra 2 step launch control vid.
Old 04-16-2009, 07:49 PM
  #61
Ronin Scion
Ace83's Avatar
thats great mike, i'll send it asap.. no luck calling elementtuning today, its damn busy lol
Ace83 is offline
Old 04-16-2009, 08:35 PM
  #62
Ronin Scion
Ace83's Avatar
Aight I found these two wires right under the clutch pedal, so i assume these are the cruise control clutch switch, the black and yellow wire.. the harness comes with black and red wire, does it matter where i tap it or its is reversible?
and here's the diagram that comes with the harness, everything is all connected except Wire D that is supposed to go to pin B12 cannot be inserted since pin B12 on the hydra harness is being used, alternative to this or this wire on B12 will have to be tapped?
Ace83 is offline
Old 04-17-2009, 05:52 PM
  #63
Ronin Scion
Ace83's Avatar
lol wires i posted above are the wrong ones its the red and yellow wire above it but i had it wired right anyways
Ace83 is offline
Old 04-17-2009, 07:37 PM
  #64
mikescion's Avatar
you 2steppin yet?
mikescion is offline
Old 04-17-2009, 10:55 PM
  #65
Ronin Scion
Ace83's Avatar
^^ got a problem man, i got a problem with the settings, on outputs PWM10> PWM 11 MAP> I couldnt get the Input X and Y changed to the right settings, I load the correct map but once its online it goes back to the old settings.. i tried to change it manually while Im online but I get an error something like violation setting is password protected! thats prolly why I get couldnt get it to work, Im still waiting for phil to respond.. otherwise I might be calling hydra support to unlock it
Ace83 is offline
Old 04-18-2009, 03:54 AM
  #66
mikescion's Avatar
well make sure when downloaded to ecu then pull key for 15sec. to make sure its loaded properly then upload and check it. if that doesn't work call hydra direct and give them your box number or send them your map and they can fix it same day.
the main thing to do is stay calm it will all work out.
Old 04-18-2009, 12:54 PM
  #67
Ronin Scion
Ace83's Avatar
lol yeah.. i will need to call hydra to unlock it.. but yeah no luck i pulled the out the key for a long time but the map setting still wouldnt stay.. its cool though i wont be using it until i get my slicks, i was just excited to hear it.
Ace83 is offline
Old 04-22-2009, 03:35 PM
  #68
Ronin Scion
Ace83's Avatar
im double checking my connections, i still cant get it to work lol..
so this is the clutch line I need to tap right? do I need to wire the relay to a 12v power source?
Ace83 is offline
Old 04-22-2009, 08:36 PM
  #69
mikescion's Avatar
its the cruise controll clutch switch. unplug it and wire it to the clutch switch side. in other words your cruise won't work again but shouldnt be to hard. follow the clutch pedal up you'll see the harness and go from there
Old 04-23-2009, 01:46 PM
  #70
Ronin Scion
Ace83's Avatar
Phil confirmed that my settings right but i think its my wiring.. What I did is tap the yellow and red wire on that harness, so its not how its supposed to be wired?
here's how the wire looks now
So that cruise control harness will have to remain unplugged? and the two wires from the hydra will go to each pin that clutch switch?
Ace83 is offline
Old 04-23-2009, 02:12 PM
  #71
yamaha16bw's Avatar
If I remember right, yes.
yamaha16bw is offline
Old 04-23-2009, 02:17 PM
  #72
Ronin Scion
Ace83's Avatar
yes to what? keep the cruise control harness unplugged?
Ace83 is offline
Old 04-23-2009, 05:13 PM
  #73
yamaha16bw's Avatar
yes.....I'm running over to my garage later today for something. I'll look and let you know around 6pm
Old 04-24-2009, 12:44 AM
  #74
yamaha16bw's Avatar
ok You need the wires on the Launch control line to be connected to the Cruise control harness. Doesnt matter which wire goes on which end. The plug the harness back into its spot.
If you dont understand what I'm saying PM me and I'll give you my number.
Old 05-11-2009, 08:32 AM
  #75
Ronin Scion
Ace83's Avatar
so how much TPS and rpm did you guys have this one set? mine only boosts around 2.25 psi with TPS 50 and 3000 rpms.. is there any map i need to tweak to tune the 2 step?
Ace83 is offline
yhwhdesign
06-11-2021 03:34 PM
SteezyScion
08-11-2015 07:40 PM
Ways808
08-02-2015 08:13 PM
2014AbsolutelyRed
Scion tC 2G Aero & Exterior
07-31-2015 05:09 AM
Subaru86
07-31-2015 04:00 AM
Quick Reply: Hydra 2 step launch control vid.
