Hydra Question
Hydra Question
Anyone able to raise their rev limit with the Hydra? I have the 2.6v on an 06' and cant seem to get it work. I know where to change it in the software, but it does not seem to do anything in the way of raising the rev limit.
Yes, we are going to try and set them both to like 5k and see if the rev limits through the Hydra are working at all. We are just trying to get to 6500 at this point
Yeah called Vinny a bit ago and he was great...very helpful, he is working with my tuner to see if they can get it figured out. Vinny was like...let me get my laptop and lets get this figured out!
What I dont get is why Andrew from Hydra convinced us to go to 2.6, and then is telling me that you cant get around the factory rev limiter on the tC....yet you can do that with the E-manage ultimate??
and what is the factory rev limiter anyway, I have heard several 6500, 6250, 6100 but the red on the tach in the gauge cluster looks to start at around 6100-6200 which usually is where the factory rev limiters are
if nothing else works, jut go to 20 psi. should put you in the 400-415 range. plus its probably 90 some degrees in the garage ur in plus 100% humidity
Yeah I think everyone has lost 10lbs while tuning, car is running really strong thought, idling good, etc.....damn rev limiter....NEMESIS
Change the rev limits in the settings menu. Both hard and soft up. Are you logging as it hits the rev limiter? Is it cutting fuel? Spark? Send me a log maybe I can take a look at it or post it here. Let me take a look at 2.6 software. I don't think there is additional setting in there but I may be mistaken. I don't see too many 2.6 boxes but have done tech support on them before.
