I dont believe Turbonetics
Originally Posted by Enthusiast
I said something about zero's post because if ytou go back and read it he said, "300whp at the crank" and whp occurs at the wheels.
Okay Zero is that at 8 psi and are the only mods to the car the turbo kit?
Here is the Cardomain of the car: http://www.cardomain.com/ride/806342
Who runs a turbo with stock exhaust? That is silly.
See even this guy uses the same formula http://users.erols.com/srweiss/calchpb.htm
What is giving these cars the extra power? The intercooler?
Every ad I've ever seen, mostly in Modified Mag, has stated 300hp with 94 octane at 8lbs of boost. The fact that they say 94 octane tells you that they fine tuned it. You'll never see that with the preprogramed unichip which runs richer (safer) . You could probably see some big numbers from 6lbs of boost tuned to 98 octane with something to cool the spark. Either way Turbonetics isn't lying to us they're just a little deceiving.
There is a forum if your really that mad about it. www.turboneticsownersclub.com
Also check here:
http://68.111.208.232:1352/viewtopic.php?t=3
Also check here:
Originally Posted by TheQuietThings
right, youre getting 247whp, add 20 whp because of the exhaust, Thats 267whp, which is about 300bhp
Whats the problem?
Whats the problem?
Whats the problem?
Whats the problem?
Just gotta be careful about blowing stuff up with high compression lol
Whats the problem?
Whats the problem?
Whats the problem?
Whats the problem?
http://www.zeropointindustries.net/s...products_id=36
and look at jamasco racings tc chris there has 14 psi and about 450whp.
Another thing that determines power with pressure is the size of the turbo, if you have a smaller turbo you can run higher psi and not get the same power as a bigger turbo running smaller psi
