IDLE A/F ratio 10.0 please help
alright, after all my other problems, i finally got my car together and running, took it home today. i let the ecu kind of get used to the new engine by cruising at about 55-60 mph for a while, now it idles filthy rich 10.0 or less, my gauge doesnt read any less.
and when im cruising, in boost, out of boost, full throttle, half throttle, it is off the gauge (over 17)
i tried disconnecting my maf, primary o2, separately and both together, it didnt help things either way, it was either too rich or too lean. i have to drive this car for a week, i cannot get it retuned anytime soon, and i dont think that is the problem, can anyone help me? pleasE!
Originally Posted by CarbonXe
Just curious, but why the flip would you go WOT when the car is running like crap? You're just asking for even more problems.
Originally Posted by bridfi
at WOT, the car runs fine, a/f r is at about 12.8-13, every other situation it is either too lean or too rich. this car ONLY wants to run at WOT.
Originally Posted by BlackKnight
Detailed specs on engine/mods/ecu or piggyback
mods - TRD s/c w/NST 9.5 psi pulley, header, exhaust, intake
ecu - 2005 tc TRD reflashed ecu
no piggyback
im thinking i need to get it retuned, but i dont think its just that. would the small differences with the engine make that much of a difference with the AFRs?
Yea 13's under boost = car go boom - i thought you had it tuned by a shop due to the phrase " i cannot get it retuned anytime soon" sorry - so yea 05 ecu with 08 motor - never tried that but doesnt sound like a great idea - 08 motor is higher compression than 05 so i would venture to guess the base fuel/ign tune would be diff. Also what intake ar eu using? If its too large it can cause it to run lean.
^^ are you 100% about that? i thought stock maf housing is 2.5 pipe? but i doubt that the problem he has though, he has major fueling issues not just sections of it.. im sure its the tune
