Idle Surging
Idle Surging
So i did a quick search on this and didn't find anything other than "the tc sometimes has a surging idle - dont worry about it" from one person in one post
Anyways, I had been driving around with a prettty bad exhaust leak (toasted the turbo inlet gasket... 1/4 of it was melted off. its fixed now) and my idle was pretty stable (oddly enough)
Now the power still feels good, but the idle is realllly jumpy when i first turn on the car, and any time when coming to a stop after boosting. It stables out after it jumps up and down to about 500 up to almost 1500 about 3 or 4 times, then is stable. Is anyone else experiencing this? Is it anything to worry about?
Well my car has always done that when I cold start, pretty sure that's just everything warming up.
And as far as the neutral stop: I think, and I'm no expert, but since your BOV just release all the air in the intake, that the MAF sensor gets a little confused. Although the HKS BOV design helps with this, it's still not perfect.
did you change your spark plugs? i've never had a problem with my hks ssqv bov and i've had my kit for almost a year.....when i changed my sparks out for colder stepped ones, my rough idleing went away....never had an issue since....
Originally Posted by Whocares05050
Strangly enough, my car just started to do the jumping thing. When im driving and i put the car in nuetral to come to a stop, it jumps up and down between rpms
Your car was just sucking in lots of air and the MAF is sensing a lot of air coming in and then all of a sudden, the BOV releases that air and the MAF goes "what the heck? Where'd all the air go?!" causing the car to take a few seconds to even out and go back to normal.
curiouser and curiouser.... i think im going to run a compression test regardless... i cant decide if i am losing power or not. My friend was saying the car sounds a lot different than it did.... and i dont break traction in 2nd like it did when i first got the car tuned, but that could be attributed to the slipping clutch im not sure... in any case at least if i do a compression test i know the idle surging is most likely nothing to worry about.
steeze69
05-24-2021 02:57 AM
rancur3p1c
07-12-2015 07:59 PM
