Injectors: Sizing for your needs!
Old 09-08-2010 | 04:06 AM
rougenite's Avatar
Default Injectors: Sizing for your needs!
I hope to give a little back to the community thats helped me out
Basic math equation for this
SIZE=(BSFC)(HPCrank) / (duty cycle) (# Injectors)
BSFC: Basically breaks down to the ratio of FUEL to HP.
HPCrank: Horsepower at the crank.
Duty Cycle: DESIRED duty cycle (Try to keep it below 85%)
# Injectors: How many injectors you have on the engine.
NOTES: Typically a turbocharged BSFC will be between .50-.65 lb/hr-hp. This is dependent on the Volumetric Efficiency, the turbo and how well the EFI is tuned. I will be using .65 for 'wiggle room'. Horsepower will be 400. Duty Cycle will be 70 and 4 injectors will be used.
Now on to the math
1) SIZE= (.65x400) / (.70x4) = XX.X lb/hr
2) SIZE= (260) / (2.80) = XX.X lb/hr
3) SIZE = 92.85 lb/hr
4) convert lb/hr to CCs (92.85)(10.5) = ~975
So, as it is in this equation, if i want about a 400HP tC, I will need 1000cc injectors.
If you increase the duty cycle more you can work with smaller injectors.
Again, please remember that the BSFC will vary from car to car. If you stick with the .65 and a moderate duty cycle, you cant go wrong with this!
Quote:
Originally Posted by paul_dezod
Note that this is also contingent upon a consistent fuel pressure. Should you have a return pressure system with a rising rate FPR, your size injector needed will be less because as pressure increases, flow rate of injector increases.
MOST (not all) injectors are rated at ~44PSI OEM. (of course this changes from car to car, but thats something you can figure out on your own!)
What Paul said is completely true more PSI= smaller injectors.
THIS IS JUST AN EXAMPLE NOT NECCISARILY FOR THE TC!
New Pressure = (Old Press)(New Flow Rate)/(Old Flow rate) 2
NOTE: Hopefully you can understand this PEMDAS is required. Think back to High School or 8th grade math. Bold 2 means 'squared'
Say we want 450cc of flow from out 370cc injectors.
[(450/370)2 x 44]= New Pressure
450/370 =(1.216)2
(1.216)(1.216)= 1.478
(1.47) *(44)= 65 * Is multiply...cause itll put a smily in there
So if we want our 370cc injectors to flow like they are 450's we need 65PSI of fuel to flow.
Last edited by rougenite; 09-28-2010 at 09:59 AM. Reason: Added info from second post to clean things up.
Old 09-08-2010 | 04:09 AM
trd07tc's Avatar
http://rceng.com/technical.aspx
Old 09-08-2010 | 04:21 AM
rougenite's Avatar
This thread is meant to be a help to our forums. More info in one spot= less time searching.
Old 09-15-2010 | 05:42 PM
paul_dezod's Avatar
Scionetics
KAD
Now on to the math
Old 09-15-2010 | 08:20 PM
SoccerBoy_AP's Avatar
Awesome info... now I know that in order to efficiently achieve 280hp I need to swap up from the 440cc's that came with the S/C to 550cc injectors...
Old 09-16-2010 | 01:03 AM
Rasta's Avatar
I have some 160lb in mine. Not sure if its overkill I want to make about 550whp we will see wut up soon.
Old 09-17-2010 | 04:47 AM
deathbyc4's Avatar
rising rate FTW, makes it harder to tune (if the vacuum source is not reliable) than constant fuel pressure. However, making over 400 crank on 440cc injectors is rather astounding
Old 09-20-2010 | 12:13 PM
Ace83's Avatar
Ronin Scion
also consider how the manufacturer rated their injectors, it might be possible for them to rate an injector at higher fuel pressure to bump up the numbers "CC". If you have the psi rating available then check it coz you could be misled. Most use the 3 bar pressure though which is pretty much standard.
Old 09-20-2010 | 10:46 PM
rougenite's Avatar
^ correct indeed I keep the suggestions on what needs to be added. More input = more information I can put in to help more people!
If you guys want I can do a tC only, then most of the guessing will be taken out. LMK what you want guys!
Old 09-27-2010 | 01:50 AM
rougenite's Avatar
No inputs? Going to get the next batch typed up and the info put into one post.
rain7905643
03-14-2015 01:48 AM
ColonelSanders85
03-03-2015 04:31 AM
meechindisbeech
Scion xB 2nd-Gen Wheel & Tire
12
02-28-2015 05:20 AM
paolodoctolero
02-22-2015 07:35 AM
