installing my supercharger
As for the pan just drill and tap the one you have or have someone weld it. As for the pipes just stick with the rubber ones, I don't think you're gonna find the metal ones... Could just have them custom made at a shop if you want them so bad. Since your car is an 08 I think you need a fit kit, or maybe that's for autos
When I put my used s/c kit in I got the trd bolt and put it in. I wouldn't want to risk having the crank bolt snap. If it does you are pretty much screwed you would need a new crank shaft or spend a small fortune having it drilled and tapped. They use the new crank bolt for a reason.
ColonelSanders85
12-09-2020 09:44 AM
TheTripleC
01-04-2015 06:46 PM
TheRedBox
31
12-02-2003 04:53 PM
