Internals for S/C Application
#41
Originally Posted by tCUZZ
Originally Posted by Prototype_xB
i wouldn't waste $$$ on getting internals with the s/c. You're not gonna be pushing anymore power than the stock internals can take anyways. Plus if you do spend the money, you'll have lower compression pistons compared to stock and be making less power with the s/c than you would with stock internals.
Back to the "you dont need internals" - As of now - nobody can really state that as a fact. We are assuming that 300,310,320,330,340whp is safe ...but for how long? After how many years till the engine dies by breaking a rod or something? ...we shall find out. If the upgraded rods are good for 400 and 500 hp ... you would assume that the stock rods are rated at a bit over 300hp. So .... think about if internals are or arent needed.
#42
i agree.....
300hp is relatively simple with the s/c...not as easy as a turbo, but not impossible....heck kytc has nearly done it without ANY internals or headwork(correct me if i'm wrong, but pretty sure), so it's not too hard....just some hard work, and self/custom fabrication..
now with the cams, headwork(port and polish), upgraded rods, pistons, etc, and a nice tune, it can be done....
300 whp is considered the current limit on stock internals.....some people will have problems here, some wont, just depends on luck and what not...same variables as the pulley debate, who knows...
good luck with the pistons....higher compression means higer hp, but it also requires better fuel...for a DD run lower compression, otherwise stay near the stock compression....
i agree.....
#44
Originally Posted by zer0
Arias Pistons are $155 a cylinder. Those are custom made. For 20psi+ applications add $15.
#46
I just can't get over that ( i think joe ) snapped that shaft with such little hp. Im guessing you had another one custom made?
#47
Joe snapped the axles due to more than power. The Dezod kit during that stage of development had a very aggressive torque curve. Add the drag radials and the new clutch to the torque spike and you have some crazy forces acting on the CVs from all sorts of angles.
Well, namely the instant power delivery of the clutch and the super sticky tires acted in opposing directions on the axle. If you watch the video again, the car has no traction for a split second and as soon as the tires grip, the axles go snap.
Remember that the weakest link is always the first to go. In most cases, that's the tires which means you spin your tires. In this case, the tires held on too well.
And as far as compression goes, I think Diablo is getting something wrong here. Low compression doesn't make more power with forced induction. Low compression only allows for more boost, safely. The idea is to run as high a compression as possible with as much boost as possible. Super high compression and super high boost means explosions galore. Since more power is made with more boost, people usually sacrifice compression for a lot of safe power. If you're going to run a mild set up, you should run a higher compression.
#51
how can you possibly state that? come on people. You can easily get 300whp out of the s/c .... Easily! yes its going to take some money but you can easily do it. Most people on this forum are kids and young adults that do not have the money to throw $$$ into hooking the car up. Just wait till next year ...there will be a good handful of 300+ hp s/c tC's. You haven't seen it yet because most people buying the s/c is for warranty work. Once that fad goes away and people start tuning them, changing the cams, and adding more boost w/ methanol ... 300+ hp is easily obtained. just wait.
#52
#54
All I can say is I'm debating on low and high compression. I thought high compression is not a good idea cuz it could lead to engine blown up which I don't want to risk it. Never know in years later, there will be more product for S/C application to boost more. I talked to RIPP and said he can't answer which comression ratio will be the best because he is working on one part at a time and when it comes to the piston, he will tell us which is which. I'm glad to have RIPP working on tC's S/C as well as he did for the custom cams and hopefully he could do the piston/rods too. I think I should wait on him and do a little research. My first thing is to do the head as custom cams and port n' polish. I would like to see more success with the S/C, not only turbo who can say "you should have bought the turbo instead of S/C". It is nice to have turbo in the tC but a lot of people have turbo so I want to do something different. S/C is fun and challenge but it a lot of money to spend than turbo application and I'm ok with that.
#55
#56
RIPPMODS RULES!
#57
RIPPMODS RULES!
Subaru86
Scion FR-S ICE & Interior
09-10-2015 08:11 AM
umnitza
09-01-2015 08:06 PM
umnitza
08-21-2015 12:35 AM
