Issue Starting Car
Issue Starting Car
So recently my car has been having trouble starting n the battery is ok n alternator is ok so i am seeing if i could get some help it does it on and off n sometimes it takes a couple cranks n then it turns on now here isthe tricky part the car drives fine afrs r perfect accross the board as well
Sent from my iPhone using Tapatalk
yeah i jus got back home from class ima check the plugs n f/ic wires to make sure they are all in the pins cause u never know what freak thing could happen but i wouldnt think it would be the map on start up mike tuned me back in the begining on june n the car has run fine n started up fine it has been a recent issue over the past 8 days or so but its starting to happen more frequent now i went to start my car to go to class this morning n it took about 3 cranks n then it started i got out of class which the car only sat for about 1 hour 25min n it took me 4 cranks for the car to start
i jus checked the plugs n they were ok nothing out of the usual n f/ic wires were fine as well....could the fuel pump going out only cause it to take long to start up or would it affect driveing as well?
Dear John,
You may want to look into the AEM FIC it self, As we have seen many of those units add additional crank time to starting, mostly due to the way it intercepts cam/crank signals. Some work like oem.. Some take extra cranks!
I would say 4 turns on a AEM FIC is normal. But maybe check with others here, and or friends.
Have a good day
Have a good day
nah chad its not like that i understand that takes a bit longer to start with the f/ic im talking about like for seperate time i have to turn the actual key sorry i shoulda been more specific as well mike
yes i do but nothing out of the ordinary and the codes have already been discussed with mike n i am not equipped to check the rest
justin i lold at that
but yesterday i decided to play with the f/ic wires n they were all in and stuff nothing out of placed but all i did was play around with them n the last 4 times and it started perfect so now im really puzzled...
cid_mcdp
01-05-2015 02:45 PM
TheTripleC
01-04-2015 06:46 PM
fluxingnation
12-26-2014 04:28 PM
