Jessicas Turbo Scion TC, NEW setup IN-CAR vid WG spring pressure
Old 09-28-2009, 10:05 PM
tofast4u's Avatar
Default Jessicas Turbo Scion TC, NEW setup IN-CAR vid WG spring pressure
New setup at wastegate spring pressure of 18 psi, makes really about 19 psi- spiking to 19 by 7900 or so. I threw stock wheels back on that had some not so big 225 BFG drag radials( I had them laying around so figured I at least do a few logs with them in hopes of traction, better than the toyo street tires.. This is on 100 unleaded (vp streetblaze 100)
Car does really well, Ill post a vid of street drivability soon, I have a few more things to do with the tune and it will be completed. The new 67mm TBB has a custom 4 Iinch inlet TO4E compressor housing .60 a/r with a 2 1/2 inch IC outlet compressor cover,and a .63 a/r hotside. Also a few more little things I added including an anti-surge cover. This thing whistles a whole lot..
http://www.youtube.com/watch?v=8bkymhCUxR4
tofast4u is offline
Old 09-28-2009, 10:08 PM
ElevationTC's Avatar
Justin... WHen you get a second toss over the standalone map uve mad with the ptuning kit.. id like to see what you have done with it!
Did you switch the coil dwell in the wizard?
And when ever your ready i got a fix for the a/c and idle ;)
ElevationTC is offline
Old 09-28-2009, 10:10 PM
CarbonXe's Avatar
http://www.filmtools.com/gripprob308m.html
Invest in one of these.
CarbonXe is offline
Old 09-28-2009, 10:17 PM
tofast4u's Avatar
Originally Posted by CarbonXe
Damn I do want one of these, I think this is what Titan Darin and S.W. use on there low 8 and 7 sec street supras!
tofast4u is offline
Old 09-28-2009, 10:30 PM
tofast4u's Avatar
Ive atually had an easier time with the idle with this kit..lol.. I dont know. But it still isnt perfect, Id like to see if you were able to make it drive by wire happy ;)
Also yes fix for AC please.. She has an 07, I dont know if it will work or if you are using an output on the aem somehow?
No I didnt touch the dwell factor, I figured the base map already was correct, so I left it, I also called aem and they said it I increase it, it could fry the output or coils,if its already set correctly (happens alot with aem..) lol. Im from the supra community.. haha
tofast4u is offline
Old 09-28-2009, 10:35 PM
Just goto coil setup wizard and click on the tc.. it set up pefect from aem ;)
Old 09-28-2009, 10:42 PM
t_urbo_C_harged's Avatar
Wow! That's amazing!
t_urbo_C_harged is offline
Old 09-28-2009, 11:07 PM
Thorium06's Avatar
holy speedometer!
Thorium06 is offline
Old 09-28-2009, 11:23 PM
ValenciaS's Avatar
thats awesome keep up the good work!
ValenciaS is offline
Old 09-29-2009, 04:47 AM
So now you are on the complete p-tuning kit? What differences have you noticed as far as turbo lag vs. dezod log, kit fit and completeness, and tunability with a blow-thru MAF setup as apposed to the dezod setup?
Old 09-29-2009, 05:53 AM
SoFloTC's Avatar
^ the answer is... ptuning owns
SoFloTC is offline
Old 09-29-2009, 06:02 AM
all4degame's Avatar
i think i just crapped myself... wow. simply amazing! good work
all4degame is offline
Old 09-29-2009, 06:04 AM
Domo's Avatar
Domo is offline
Old 09-29-2009, 09:36 AM
NVMyTc's Avatar
Open dump wastegate im guessing lol
That thing sounds nutz!
NVMyTc is offline
Old 09-29-2009, 10:34 AM
Ronin Scion
Ace83's Avatar
nice new spring and new turbo kit? hitting the dyno soon?
Ace83 is offline
Old 09-29-2009, 02:11 PM
tofast4u's Avatar
Turbo lag is less, I also went to a 4 inch lnlet compressor housing, and a 2 1/2 outlet compressor housing, 3 inch DP and 3 inch exhuast, versus the 2 1/2 and agency power 2 1/2 exhuast.. The EL maniflod is a nice, very nice piece of course, and the guys at ptuning are great for taking care of me like they did.
Blow-thru wont matter so such on mine since it has an Dezod/ AEM kit it only uses MAF for IAT's im pretty positive, since its speed density.
tofast4u is offline
Old 09-29-2009, 02:12 PM
tofast4u's Avatar
Yeah, nothing less than 27 psi either.
tofast4u is offline
Old 09-29-2009, 02:40 PM
Music City Scions
rhythmnsmoke's Avatar
Cheaper and bigger....
What I use
http://www.chasecam.com/mount/suction/SM31
I've tested it at 140mph. Holds like a champ.
Nice vid by the way....Traction FTW! LOL...
rhythmnsmoke is offline
Old 09-29-2009, 02:45 PM
Music City Scions
Are there new pictures of the engine bay? Full shot's with the car and hood open would be nice. Good job man. Looking real Beastly! Address the traction problem and damn it will be stupid fast.
Old 09-29-2009, 02:51 PM
bdis3's Avatar
good lord. In for pics as well.
bdis3 is offline
Quick Reply: Jessicas Turbo Scion TC, NEW setup IN-CAR vid WG spring pressure
