just installed turbo.. need some help!!!
#47
Ok...
1.) Remove the T from the wastegate to turbo line. It should be a straight shot from turbo to gate.
2.) You didn't T the tbody line, persay - it's more of the VSV line and I'm not sure if it could cause any issues - I've never used that particular line. They say that a vac line is a vac line, but not necessarily so.
3.) Where is the 2nd port on the wastegate? I'm not familiar with OBX, but usually a top port is left open unless you have a boost controller. The side port is where the vac/boost source should be.
#50
ok so i should use the side port on the wastegate instead of the top? it has a side port and i just left it open. So can i move the vac line to the side port and leave the top open or should i plug it?
and what vac line do i use for the bov if you say thats not the right one?
