Just a shift light or a Tac?
I'm going to be switching mine back to stock so my TWM stg2 SS should be for sale soon. This is the shift light I have.
http://www.summitracing.com/parts/SUM-G2945/
why is that? going back to stock i mean.
I'm no longed interested in drag racing, where a short throw is great for. You shift in one direction and for a short period of time. But if you are into road racing and time attack like I am now, where you shift often and in both directions for a greater period of time. Synchros seem to wear out a lot faster and sooner than a stock shift or one less aggressive than my TWM stg2 when it comes to RR/TA. I need to be an easy transition into gear when coming off a bank at 100+ MPH into a turn that's 180 degrees going back the opposite direction. The TWM stg2 is a lot more knotchy and a little more aggression is need to get into gear. Great for drag, not so much for track.
I just ordered the same one as rhythm and i found this http://clubsciontc.com/forums/diy-in...install-32859/ for the install but i was wondering if there is another way?
Mine is to the ECU wire, but you can get the tach signal off the gauge cluster.
Would have to go out in the cold for that info. Don't remember off top of the dome. But I don't think it makes a difference, if you go by your own tac rather than the numbers on the back of the shift light. I just run it out and adjust the light to come on as I make multiple runs. Once you get it in the general shift area via the numbers on the back, fine tweak it by making a few passes and turn the **** +/- and adjust to your reaction time when you see the light and redline.
2008ScionXbGold
11
08-15-2016 10:50 PM
NonStopTuning
06-29-2015 07:42 PM
