Long overdue: APR Power In-line ECU Release (Screen shots PG7)
Old 03-09-2010, 06:56 AM
  #181
ScionFred's Avatar
Originally Posted by paul_dezod
So I was doing some homework with one of the engineers this week on this unit for the xB, and so far all seems like a green light for this. The cam and crank sensors thresholds and outputs for the xB 08+ appear to be the same as the tC, which was one concern for the engineer whom I was dealing with. So next step will be real world testing on the xB.
That's good news. Speaking of crk and cam sensors, in the course of your FIC testing on the XB2 did you ever use an oscilloscope? I was very surprised to see that my oem crk sensor outputs a +/- 10V analog sine wave and the FIC outputs a +/- 5V digital wave form. The oem cam sensor outputs a +/- 3V analog sine wave and the FIC outputs a +/- 5V analog sine wave. The FIC ouput voltages were totally unaffected by reducing the oem sensor signal inputs. For some reason unknown to me, attenuating the already low voltage cam signal down to +/- 1V seemed to eliminate the misfires and crk sensor codes that have plagued me. Reducing the 10V crk signal only made things worse for me but Rustin (Boomslang) has been dealing with a shop with Corolla FIC issues and in their case they had success by reducing the crk signal while leaving the cam signal alone. WTF?
AEM tech support assures me that the ECU only looks at where the sensor signal waves cross 0V and is unaffected by the signal voltage and pattern (analog or digital). This is well outside my area of expertise. If you have any thoughts on this or could run it by someone, I'd be very appreciative.
Thanks Paul.
ScionFred is offline
Old 03-09-2010, 05:18 PM
  #182
Scionetics
KAD
paul_dezod's Avatar
Thanks Paul.
I wonder if the FIC has an issue recognizing the 36-2 crank sensor pattern. Which means that by adding resistance (lessen voltage) it needs to be scaled back to say 12 teeth so the FIC can recognize it.
paul_dezod is offline
Old 03-09-2010, 07:25 PM
  #183
Scionetics
KAD
paul_dezod's Avatar
Harness for the xB is done. I will start playing with it over the next few days.
Old 03-12-2010, 08:07 AM
  #184
ScionFred's Avatar
I don't think that's it. If you're interested I'll call you with the details. I'd rather not post them here for the benefit of a certain individual who refused to share any info with anyone when he thought he had the solution.
Old 03-12-2010, 02:33 PM
  #185
Scionetics
KAD
paul_dezod's Avatar
I'd be interested to hear your thoughts after all of the headaches you have been through.
Old 03-12-2010, 02:44 PM
  #186
crush02342002's Avatar
as would I
crush02342002 is offline
Old 03-12-2010, 05:32 PM
  #187
Scionetics
KAD
paul_dezod's Avatar
Originally Posted by crush02342002
as would I
Pleasure speaking with you as always.
Old 03-13-2010, 07:34 AM
  #188
ScionFred's Avatar
Hey guys, I'll PM you.
Old 03-13-2010, 12:08 PM
  #189
dito
Old 03-13-2010, 07:39 PM
  #190
Scionetics
KAD
paul_dezod's Avatar
Got it! Will hit you back
Old 03-15-2010, 05:07 PM
  #191
Shift_N_Red's Avatar
I've had this in my hands for a while now.. and will be posting up dynos for an N/A application in the next few days.. I go in for tuning on the 17th.. I will keep everyone up to speed.. and let you know what I find out...
I have high hopes for this unit based on all that I have seen ..
Shift_N_Red is offline
Old 03-15-2010, 06:49 PM
  #192
Scionetics
KAD
paul_dezod's Avatar
Alex! Curious to see what you can get with unit N/A
Old 03-16-2010, 07:39 AM
  #193
TCpete's Avatar
i heard he was using that now for his EMS... im hoping his results turn well... if he tosses it i might jump and try to cop one and use it to see what i can squeeze once im done with all my kinks
TCpete is offline
Old 03-16-2010, 05:00 PM
  #194
No doubt.. the BC Stage II cams are in and did about what I expected..
{for those that wonder.. the MILD cams saw a loss of 6whp below 5k and a gain of 7whp over 5k and pulled all the way to redline}
Anyway the tune will be done with a full I/H/E/P/Cam Setup.. so we will see what can be pulled out of her..
Keep your phone near you Paul.. I may be calling you tomorrow.. LOL
Old 03-16-2010, 06:45 PM
  #195
Scionetics
KAD
paul_dezod's Avatar
Good to know Alex. I am curious to see how it all goes at Tony's.
Cams are only a good investment if you spend the time tuning.
Old 03-16-2010, 07:43 PM
  #196
TCpete's Avatar
6 whp is a considerable drop below 5k... im trying to figure out why which i can only attribute it to tuning. what was the fuel/timing looking like at that rpm if u know?
TCpete is offline
Old 03-16-2010, 07:59 PM
  #197
java09's Avatar
i like turboz
java09 is offline
Old 03-16-2010, 08:20 PM
  #198
DezodDon's Avatar
Probably has more to do with how the runner and cylinder fill now that he has changed lift and duration over stock. Those cams have effectively moved the entire power band and he is still on a stock intake manifold which has long runners. The refraction of the pressure wave which fills the port between opening and closing has probably been weakened at those rpm for the given compression of the engine. With a weakened pressure wave signal you get a lower velocity of runner and port filling which makes for a lazier engine at certain operating conditions. If he could change the VVTi settings there he could take advantage of the new lift more.
DezodDon is offline
Old 03-16-2010, 08:26 PM
  #199
TCpete's Avatar
yes i know that... hence why i would point my finger at adjustments in that range which was why i was asking parameters. im having the same issue only low in the rpm range and only for a few hundred rpms where the car bucks.
TCpete is offline
Old 03-16-2010, 08:36 PM
  #200
DezodDon's Avatar
What RPM range? What are your A/F number like when it's bucking?
DezodDon is offline
Quick Reply: Long overdue: APR Power In-line ECU Release (Screen shots PG7)
