Losing boost at 8psi
Just installed TRD s/c with NST 9.5 pulley, Weapon-R header and S pipe, and CEL elimators, and K&N drop in filter. When I am full throttle and hit about 8psi of boost the gauge drops to 0, and I loose all boost. I was not sure if the belt could be slipping or if the blow off valve can not take this high of pressure. Thanks.
Since the S/C makes boost through RPMS, either your losing belt tension, have some sort of boost leak, your boost gauge is wrong or some other mechanical issue to ne solved.
Possibly the BPV not working properly.....???????
I got mine at www.ecstuning.com. Fantastic customer service and a great price. I also got all of my Forge SPLT-Rs from them too.
07tcscion
10-08-2015 05:42 PM
crimson_sinn
09-25-2015 09:41 PM
