Lovely, my lovely exhaust leak
Old 11-14-2007, 09:40 PM
oldred's Avatar
u can simply cut the bolts, there's no problam with that
oldred is offline
Old 11-14-2007, 10:00 PM
BrianM153's Avatar
I dont have the turbo kit so I cant say I know much about this, but, I see no reason why the bolts being long would cause any problem unless it causes you to not be able to tighten them down all the way..maybe you can try using some high temp rtv along with your gasket? and alternate tightening the bolts down a little at a time
BrianM153 is offline
Old 11-14-2007, 10:35 PM
aen
aen's Avatar
So far, sealent has not worked, it was blown out under pressure, the reason the bolts dont work is because the holes that are tapped on the manifold arent tapped all the way or vice versa.
aen is offline
Old 11-15-2007, 03:42 PM
bash's Avatar
I may have a thin stainless gasket unused at the pad. I'll check tonight. Ill throw it in an envelope and mail it it I can find it.
bash is offline
Old 11-20-2007, 09:39 AM
aen
aen's Avatar
got it, i put two washers instead of just one and tightened them down like no other. and no more gap.
aen is offline
Old 11-24-2007, 01:13 AM
dodaddy's Avatar
how can you tell if there is a leak?
dodaddy is offline
Old 11-24-2007, 05:29 AM
aen
aen's Avatar
well
1. loss of power
2. wild AFR's
3. me, i put my hand near the seperations in hte setup and felt the air rushing out.
aen is offline
Old 11-24-2007, 06:18 AM
dodaddy's Avatar
ahh i see, thank you for that info
dodaddy is offline
Col168c
9
01-07-2016 06:55 AM
2CTC
09-12-2015 11:33 AM
Col168c
01-08-2015 06:30 PM
PTUNING
12-11-2014 08:09 PM
PTUNING
12-06-2014 03:58 PM
Quick Reply: Lovely, my lovely exhaust leak
