low boost turbo with trd s/c reflash
#42
Ok well on the 2006 Civic Si there is a reflash from hondata and once u reflash ur ecu u cant use emanage. I dont know if thats the case with tC but I know that usually when u reflash a ECU you are gonna run into problems adding a piggyback. Someone will just have to be a guineapig
#43
That might be a different situation though right ..? ..because thats not hondas flash for a s/c or turbo that they put out. ..im just asking/guessing.....
#46
^ I should be posting some higher s/c numbers in a few months. Im shooting for 260whp ...lets see. Thats a realistic number ... but its also going to be tuned for more "useable" hp ...and not tuned for peak hp.
#47
It's a S/C'er, the power is uber linear, so how are you going to tune it for more "useable" hp.
#48
Grand prize: One year bragging rights woohoo!
*Crowd: *ahhhhh*
Usable horsepower sounds sorta cliche. If you mean add more horsepower through a number of other mods, I understand that, but "usable horsepower" is there.
#49
newer Honda ecus are nit picky about tuning. They dont take piggyback systems too readily and tend to reject tunes from safc/emanage type of tuning. B/c they only modify the a/f signals, leaving ignition untouched and out of wack with a/f. Hence, why Hondata says its not a good idea to use piggybacks period. I'm currently doing R&D with Hondata and i've already tested 2 piggyback systems on the k-series, both showed adverse affects. TL ecus require the actual car to be present at Hondata to get a reflash. you cant even send in the ECU. Hondata is currently trying to figure out ways to bypass all the roadblocks of the newer Honda ecus instead the alternative of reverting back to throttle-by-cable for standalone systems.
hey, werent you tuned by jason? he's moving to a bigger shop and is gona become a Hondata base for Texas. Instead of sending ecu's out, he'll do the work himself.
#50
#52
Originally Posted by bcnu_702
Get a ZPI stage 1 or 2 head. That will net you at least 20-30whp, and the stage 1 is only 500bux. Nice gains!
There is a $700 FULLY REFUNDABLE core charge on this item. Once you have installed the new Stage 1 head, send back your stock cylinder head, and we will refund the core charge.
#53
#54
oh, how so?
#55
#56
Don't forget the hidden cost, if they apply.
Im not a tuner but the tuner I was talking to was saying they can tune it differently. Ive seen that they know what they are doing ....why? do you think that was a bs statement?
#57
basically jwaggz point is fine tuning will make everything run smoother and you'll gain a more power in the midrange ("useable" Hp) and make more power in the most efficient fuel/ignition settings that will yield best gas mileage at the same time.
heck, my rsx has the same gas mileage from the factory even with a lil boostin' here and there.
#58
No one called BS on you bro. I was asking a question.
