M=tuned Turbo kit : little update for now
Old 07-02-2009, 03:04 AM
  #481
weezyfbayba's Avatar
Originally Posted by ptguy08
yayyy daniels! i bet your pecker is tingling
not as much as when i see u... but yea crush 13 days i got a dr appt on the 14th... so i wont eb able to start untill like noon so ill prolly just drill the holes and get the i/c mounted.. ive still gotta take apart the mani and downpipe to put thread locker on all the bolts.. might mount the mani/turbo/downpipe also and finish the rest the 15th still gotta get my T fittings for the oil pressure sensor and gotta get the vac lines... knowing me illl prolly just do it all in 1 night lol
weezyfbayba is offline
Old 07-02-2009, 03:08 AM
  #482
ptguy08's Avatar
im so f*cking ____ed im not gona be there when you do it.
ptguy08 is offline
Old 07-02-2009, 03:10 AM
  #483
ur the one who wants to ride all the way 2 bunfukkked egypt with ur dad.. u should go see the 9-11 scene spot..that would be pretty memorable.. ill make sure i give ur car hell i mean take good care of it that is
Old 07-02-2009, 03:12 AM
  #484
ptguy08's Avatar
lol im gona mark the miles before i leave..nah your the only person id EVER trust do so somethin like this, you can hit a lil boost to hold you over till yours is on : )
ptguy08 is offline
Old 07-02-2009, 03:13 AM
  #485
na ill prob drive it to the mall and back to make sure everything is ok...
Old 07-02-2009, 03:14 AM
  #486
ptguy08's Avatar
whatever ya do is fine with me skeeter
ptguy08 is offline
Old 07-02-2009, 03:43 AM
  #487
even foreplay?
Old 07-04-2009, 10:53 PM
  #488
boost and oil pressure gauge's ordered ! install either next tues and wens or the following!
Old 07-04-2009, 10:54 PM
  #489
crush02342002's Avatar
woot!!
crush02342002 is offline
Old 07-04-2009, 11:00 PM
  #490
thanks to crush & ace for all the help also also crush on that flange the side were its got that little circle grove does that go on the outside or on the inside and bolt to the wg?
Old 07-04-2009, 11:01 PM
  #491
went and got some vacum line today also still gotta go backa nd get some 1 inch hose for the bov.. ill be upgrade to the hks bov shortly i hope.. still gotta get another fitting the size of the boost gauge line for by vaccum block? advance auto didint have any
Old 07-04-2009, 11:26 PM
  #492
the groove is for the pipe...it really helps to center the pipe and keeps you from burning a hole through the pipe when welding...i love thes flanges...the one i got from dezod kinda sucked and was a bit on the thin side. I just cant say enough about thes flanges that i get now, they just make life soooooo much easier.
Old 07-04-2009, 11:31 PM
  #493
dope ill be running open dump till i drive to my dudes house were i get my things welded at so we can get some pipe and make them fit.... try and paint it also dunno what will be able to hold that kinda heat
Old 07-04-2009, 11:43 PM
  #494
btw you can (just saying) get your pipe from home depot in the electrical section. its 1 1/4" EMT (not rigid) all youll really need is 1 1/4" emt 45 degree bend and a 90 degree bend...with those two you should be able to get it done. if you just get the bends youll prolly spend about 30bux (roughly)
Old 07-04-2009, 11:50 PM
  #495
sweet.... i should just run the pipe how far down just next to my oil pan or what? my friend has his like blowing on his engine block and its all black now i dont want that
Old 07-05-2009, 12:00 AM
  #496
most of em that i make go just past the oil pan...but i have made a couple that come just were the pan bolts on without any problems, i just make sure that the pipe is directed away from the oil pan and return line. i found that its hella easy to make a dump tube for a 2.1 mani than it is for the simple kit.
Old 07-05-2009, 06:57 AM
  #497
ughhh.. when my ac is on or when im slowing down i can hear this f'ing rattleing noise the other day i foudn that i leaked about 1 1/2 -2 qts or tranny fluid out bcuz i forgot the bolts to the axle piece that bolts to the frame but i dont think i drove to far bcuz it wasint at my work or anything.... hope its not my tranny i can see the rear mount sheking pretty good im gonna put it on the lift when im at work tomorrow hopefully its just some bs not a big deal
Old 07-07-2009, 10:48 PM
  #498
new charge pipe ordered got the recirc nipples cut off and welded today gonna go with the hks bov! hopefully the charge pipe will get here by next tuesday or no install next week
Old 07-08-2009, 04:12 AM
  #499
ptguy08's Avatar
omg omg omg omg ur so close.
ptguy08 is offline
Old 07-08-2009, 04:13 AM
  #500
to ur brown eye!
doesint matter if todd doesint have that charge pipe here by next tues or wensday then no install
Quick Reply: M=tuned Turbo kit : little update for now
