M=tuned Turbo kit : little update for now
#601
Originally Posted by crush02342002
i just used a 1/8th npt brass threaded coupler (short style). it only goes in for about 2-3 threads. the hole for the stock sensor is tapered so if you can find an 1/8 npt tappered thread coupler then that would be best but a regular 1/8th npt will do. use teflon tap, it is your friend but just be carefull not to have loos pieces of it cloging up the hole.
You don't have to worry about it clogging anything up and restricting oil flow.
#602
#603
lol this ____ is just unreal.. now 1 thing went smooth not 1 lmao im gonna take the oil sensor and the fitting and show the parts store tomorrow if i can get a break at work and mayb they can find something else because that ____ just aint working ill post a pic 1 sec
#605
the selinod that wires to the boost gauge then has a vaccum line that goes to my vacc block it came with a little filter thing like the hks bov.. i didint use it think it will be fine?
#607
#610
welll i rele fukked up now i had one of the fittings started like 2 turns and it stripped tryed to put the stock sensor back in and it just trys to go in sideways... im gonna have my dude come over tomorrow hopefully and retap the hole... fml man
#614
its better to get more threads in for sure. dont do anything els till you clean those threads out with a tap, you could end up just doing more harm than good.
btw here is a better pic but its preinstall of turbo kit (didnt keep the filter for long so i dont want to hear it from anyone...lol)
#618
oh and about taping it you may get some shards that may fall into the engine...so by all means be carefull with it and remember that those are tappered threads to by tapping it you will widen it out which will help for a standard 1/8th fitting to fit better if you go all the way. but again you run a high risk of getting shards into the engine so try not to go all the way but far enough to be able to get more than 2 threads on that coupling.
#619
what is it bad to use a filer there? i dont rele plan on getting a catch can
